Black Smoke + Misfiring
Old Jul 9, 2007 | 06:24 PM
1blk4runner's Avatar
94 4Runner 3.0. just installed thanks to help from you guys,,and she is throwing black smoke badly..running super rough like a cyl misfiring..
Changed EGR,
Distributor,
Fuel Press. Reg,
Wires,
plugs(NGK),
Cap/Rotor,
Checked timing and threw light on all wires,,,a few are not giving steady flash.
Coil lead is mostly steady but random pauses in timing light which correspond to misfire although a little later like .25 sec.
Thats when I changed Distributor but no change.. I have a ton of spare parts but no coils,, Is there a way to confirm a bad coil?
Old Jul 9, 2007 | 06:26 PM
4runnerx3's Avatar
Check the air temp sensor inside the AFM and the water temp sensor for the ECU, those are 2 things that can cause flooding.
Old Jul 12, 2007 | 07:43 PM
I found the problem...changed O2 Sensor and still there.. while I was fiddling around I leaned on my MAF/Air Filter box and it ran great..
Changed MAF and still ran like crap...Connecters inside plug were backing out of plug itself..
Thought I would update all.
Thanks so much for the help along the way
WOOOHOOOO!!! SHE IS RUNNING!!!!!
shooter86314
Jan 7, 2016 07:05 AM
whiteyota93
Sep 29, 2015 02:31 PM
voiddweller
Sep 28, 2015 11:21 PM
larrys93pickup
Sep 17, 2015 07:05 PM
Boomer8404
Sep 10, 2015 09:01 AM
