1993 pickup truck 3rd gear grind
Old 07-05-2007, 08:31 AM
phatmitzu's Avatar
Picked up a 93' 2WD truck yesterday with 188k miles. Engine is running strong and smooth. Only problem is that about 70% of the times when I shift into 3rd, it grinds. Most of the times is when I upshift or downshift at a higher RPM.
Anyone know what the problem might be?
Thanks in advance.
Old 07-05-2007, 08:37 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Hmmm....could be clutch going...could be needing a new shifter seat bushing...might need to flush clutch fluid....could be synchronizer in tranny. Does the clutch ever slip?
Do a search on shifter seat bushing and GL-4 gear oil. There's good info in threads related to these topics that could give you some tips and places where to start tracking down your problem. A simple fix...like these two...may be all you need. If neither of these fix it, they are still a very good thing and comparitively inexpensive.
Old 07-05-2007, 10:03 AM
snap-on's Avatar
if memory serves 3rd gear syncro was the the most common one to go first.
try speed shifting and see if you still get the grind...
Old 07-05-2007, 11:20 AM
Zealot's Avatar
Think your right snap-on, I believe 3rd gear is the first to go.
Ya might want to try replacing your tranny fluid with Shock Proof, the stuff works great and helps worn trannies.
Old 07-05-2007, 12:25 PM
phatmitzu's Avatar
Thanks for the help guys! I don't think the clutch is slipping. Not that I can feel anyways. I'm going to buy these...
- Heavy Duty Shifter Seat from Marlin Crawler.
- Red line MT-90 75W90 GL-4 Gear Oil (How many bottles do I need??)
Anything else I should get/replace while Im at it??
This is my first Toyota pickup. Im excited and planning on keep it for awhile.
Old 07-05-2007, 02:56 PM
^VooDoo^'s Avatar
Yep, 3rd gear syncro but Im sure the bushing wouldnt hurt
Mines been gone along time But ive gotten used to shifting cars w/o a clutch so it doesnt bother me.
Old 07-05-2007, 03:30 PM
phatmitzu's Avatar
The synchronizer. Is it fixable?
Old 07-05-2007, 07:43 PM
thook's Avatar
Yes, it's fixable....meaning rebuild. But, personally I'd try some of the simple and inexpensive things FIRST. I had grinding issues and feared the synchros, but a new shifter bushing and the gear oil completely solved the problem. If it doesn't, you're not really out anything because with that mileage the seat bushing is probably toast, anyway. If you have slop in the shifter it's a real good sign. And the gear oil...well, it was worth a shot. Might even be reusable. The seat bushing...and cap...definitely is.
Old 07-06-2007, 11:07 AM
phatmitzu's Avatar
Alrighty. I'll get those done and see what happens. Hopefully it will fix the problem.
Thanks all!!
Old 07-06-2007, 12:01 PM
4bytruckin's Avatar
hows first gear? if it's like the 4x4 tranny behind a 22r it would be funky if it was a sychro
Old 07-06-2007, 12:17 PM
phatmitzu's Avatar
All other gears are perfect. Smooth.
Only 3rd gear, and only when I shift at higher RPMs. I tried to speed shift, much less grinding if any. But I dont feel like speed shifting all the time...
Old 07-06-2007, 12:52 PM
Robrt32's Avatar
I use to have a Nissan that 3rd was messed up in.. I just skiped it.. I drove like that for 2 years and sold it.. far as i know.. dude is still driving it that way
Old 07-06-2007, 02:46 PM
thook's Avatar
Oh, if it's a 5spd you'll need a little over 4qts. Drain it hot...reasonably.. so you get out as much of the old as you can. AND! Make sure you can get your fill plug off BEFORE you drain it.
Old 07-06-2007, 03:10 PM
thook's Avatar
Oh, if it's a 5spd you'll need a little over 4qts. Drain it hot...reasonably.. so you get out as much of the old as you can. AND! Make sure you can get your fill plug off BEFORE you drain it. Besides doing the seat bushing and end cap, there's really nothing else to replace at this point.
No hills in Mississippi?
Old 07-06-2007, 03:13 PM
phatmitzu's Avatar
Oh ok. Thanks!
Old 07-06-2007, 06:09 PM
Robrt32's Avatar
Not in the Delta... Any hill that is here , I never have to leave 5th if i'm running 55
Old 07-06-2007, 08:08 PM
thook's Avatar
I've been through a few times. Helena Blues Festival was a nice stop. So, I know....flat, flat, flat. I was just messin'.
phatmitzu- Someone advised me to fill the tranny from the shifter when I was doing what you are going to be. It makes it very easy. Just have a clean drip pan underneath to catch overflow from the fill hole. That way you also hear the "plop" hitting the pan and know to stop....if you are doing it by yourself.
Old 07-08-2007, 01:22 AM
isaac338's Avatar
i think that works fine on a w56 but on the r150f it's not so good - something about the transfer case and tranny sharing fluid and the tcase not getting any if you fill through the shifters.
might want to do more research before you use this method
Old 07-08-2007, 02:08 AM
Robrt32's Avatar
[QUOTE=thook;50567830]I've been through a few times. Helena Blues Festival was a nice stop. So, I know....flat, flat, flat. I was just messin'.
Ive been to the Blues Festival a few times.. I live about 20 minutes from Helena..I travel pretty close you in November of every year.. We go to Cabot for a few days and visit my sister..
Old 07-08-2007, 02:10 AM
Robrt32's Avatar
[QUOTE=Robrt32;50567995]
EDIT, Oops i thought you were in Little Rock
Quick Reply: 1993 pickup truck 3rd gear grind
