question about coil spacers and road handling
Old Jul 11, 2007 | 10:40 AM
taikowaza's Avatar
I just recently switched my 32x11.5s for 33x10.5, along with new t-bars and a 1" sdori coil spacer.
I've been noticing a big change in the handling on-road and wanted to ask for some opinions.
Everything feels much more 'floating' in the rear end, I feel when I turn that the rear is drifting a bit.
I am sure that with the new height/clearance that this will take some getting used to but the feeling is a bit unsettling so far. Any ideas or comments much appreciated! should I naturally expect a 'tippier' ride with the narrower tires and lift, or would you guys recommend removing the spacers and lowering the t-bars to gain more stability with a 10.5" width
Old Jul 11, 2007 | 11:37 AM
ZUK's Avatar
ZUK
1 inch in the rear should not do that.....perhaps some bilstein 5125 series gas shocks would fix that?
Old Jul 11, 2007 | 02:30 PM
taikowaza's Avatar
thanks zuk!
thanks zuk! good to hear from you and thanks again on the gearing advice.
yeah 1" in the rear shouldn't have such an effect, I think that it's the combination of going to narrower tires and adding a spacer that has given me this feeling, I may just have to get used to it.
I am running ARB shocks so I think that should be sufficient...just one last question- does the fact that there is a spacer in there make the coil/shock compress more/deeper? This may be the 'floating' feeling that I am getting, that I never felt before, and it may just be the ARB shocks compressing deeply for the first time.
Old Jul 14, 2007 | 08:30 AM
FredTJ's Avatar
What kind or tires and what pressure are you running them at.
That can make a big, big, difference.
Fred
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
