Where is the No. 5 water by-pass hose??
Old Jul 12, 2007 | 07:06 PM
snelson's Avatar
Hey all
My very first post here - I'm just getting started removing the heads from my 92 V6 4x4 - and using the FSM step 18(e) says to "remove the No. 5 water bypass water hose" http://personal.utulsa.edu/~nathan-b...68cylinder.pdf- but I can't figure out where the heck this is located? Anyone happen to have a picture or could describe the location for me?
Thanks very much.
A quick background - just finished replacing my timing belt - reading the previous owners service records they had to have the dealer re-thread #3 spark plug hole - I changed all the plugs as part of my timing belt job, and pulled out the remaining #3 threads in the process - dohh - so - now I get to pull the heads and get an insert put in, and new head gaskets while in there.
BTW - I'm a total 'hack'-yard mechanic with minimal exp. but I figure with the help of this wicked site and the FSM - I should be able to get through this.
Thank again for any help
Steve
Old Jul 12, 2007 | 10:07 PM
MudHippy's Avatar
Yeah, you'll do fine.
You'd have found the hose when you went to pull the plenum off with it still connected. Here's a couple pics. It's to the right of the throttle body there, in that general area.
the1998sr5
15
Jul 14, 2020 08:35 PM
gtwnbill
Engine Swaps
Aug 18, 2015 04:07 AM
94 Newbie
Aug 6, 2015 10:33 AM
jjrbus
Jul 23, 2015 05:05 PM
jjrbus
Jul 19, 2015 02:06 PM
