4runner CEL
Old Jul 10, 2007 | 09:44 PM
strykersd's Avatar
4runner CEL
My 86 4runner has been throwing a check engine light lately. It lights up for a few seconds and then goes away, so I never have the time to check the code. It never happens at idle, only when cruising. Any ideas?
At first I thought it was the O2 sensor, I changed that and it still hasn't gone away. Oil pressure and coolant temp seem fine on the gauges. Thanks for the help.
Old Jul 10, 2007 | 09:49 PM
stormin94's Avatar
Check you oil level. You can still have decent oil pressure even if it's a quart low. Also, check your gas cap, and make sure its on tight, or check your exhaust for leaks. And if this doesn't fix it, you can always get a code reader, and read the codes.
Old Jul 10, 2007 | 10:38 PM
Jay351's Avatar
If your truck has thrown a code then it has stored the code in the computer.
Jump the connectors (pretty sure its e1 to te1) with a paper clip then turn the key to the start posistion.
count the blinks and then decifer it.
BeMiceElf
Oct 10, 2015 09:40 PM
v_man
Jul 23, 2015 04:01 PM
Sandman
Jul 14, 2015 12:36 PM
Roger Borba II
Jul 9, 2015 05:05 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
