AHHHHHHHH! 88 pickup 22re Coolant on the passanger floor...
Old 07-07-2007, 10:18 PM
07sbock's Avatar
BLAHH!!!!!!!!! coolant on the floor and it keeps over heating. SO the heater core is bad correct?
1. How big of a bitch is it to get to in my pickup?
2. Anyway i can stop the leak without replacing the core. Is it a bad line?
Old 07-07-2007, 10:27 PM
Yota4runner's Avatar
It is likely your heater core yes. You are going to need to get at it, behind the dash and see if its the core itself or a leaky line. I
Old 07-08-2007, 06:06 AM
waskillywabbit's Avatar
Heater core leak or in a line. That is going to be FUN to fix.
Old 07-08-2007, 06:14 AM
CyMoN's Avatar
it will be a pain in the ar$e but it will not be that bad you will have to remove the dash.
https://www.yotatech.com/forums/f116...umbers-102344/
Old 07-08-2007, 07:08 AM
Numbchux's Avatar
just bypass it.....you don't need heat anyway!
Old 07-08-2007, 07:18 AM
razrwild's Avatar
if you just want to bypass it that's nice and easy. If you're going to replace it then have fun with it weeeeeeeeeeeeeeeee
Old 09-03-2007, 10:37 PM
ozziesironmanoffroad's Avatar
yeah basically. its not the easiest thing to do, but once the dash is off its not too hard. just remember where everything went or you'll be like me.. spending 20 bucks on a repair guide that should have been used in the first place just to not be able to read it and guess where stuff went. works ok, but wont be the same.
Old 09-04-2007, 03:48 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
It COULD be just a line going to or from the heater core. So, check that first. But, if it is the core, take pictures while you're disassembling and keep track of all your fasteners. Easy buggers to lose.
Old 09-04-2007, 03:38 PM
84sr5yoty's Avatar
I had this happen in 1995 only to find out that the heater hose clamp needed to be tightened a little. Pulled the whole damn dash out for nothing
Old 09-04-2007, 07:45 PM
longhungsilver's Avatar
ouch
I second taking pictures... im doing a 95 sunfire right now actually... gonna finish the rest in the morning and its a terrible job and i wish i had taken pictures... iknow im getting sumwhat creative putting it back together
Old 09-04-2007, 07:51 PM
TNRabbit's Avatar
There's an FSM sticky link posted at the top of this forum....might check there first....
Old 09-04-2007, 08:34 PM
curtiswyant's Avatar
So you have to unscrew a couple bolts and disconnect a couple wires to get to it, big deal. Don't be such a ˟˟˟˟˟
Old 09-05-2007, 12:55 PM
shaeff's Avatar
i just replaced the heater core on my '94 the other day. it was pretty straight forward. (though, my previous experience was with my supra, and there are a lot more wires behind that dash, heh)
all in all, not a bad job. if anyone needs pics, i took some between beer, food, and helping my friend replace the rotors, calipers, and pads on his '91.
-shaeff
Old 10-04-2007, 03:14 PM
n4ynu1010's Avatar
Heater Core
Just start early and do the whole job the same day and your memory should make the trip , havn't done one on the Yota yet but on my SLS 4WD Jimmy , same deal had to drop the steering column and pull the entire dash out , took all day but got it done ...............Git er Done .
crashburnoveride
08-28-2015 09:20 PM
Avenged
07-09-2015 07:55 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Nickdigg
07-07-2015 06:04 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: AHHHHHHHH! 88 pickup 22re Coolant on the passanger floor...
