exhaust
Old Jul 4, 2007 | 10:47 AM
killa b's Avatar
exhaust
has anybody ever used this type of muffler i was thinking of cutting down the ends and running dual exhaust right before the tires.
wat size tubeing should i run i have a 3.4l and i was was thinking about running 2.5 inch dont know if thats to big thanks.
Old Jul 4, 2007 | 10:53 AM
Red3.slow's Avatar
2.5 will be great. I'd run 3 if i could after the muffler it'll sound better
Old Jul 4, 2007 | 10:56 AM
killa b's Avatar
you really think 3 will be good for it y not just keep the size comeing out of the muffler.
Old Jul 4, 2007 | 11:27 AM
keithguts's Avatar
What is that, One line comming out to 2 lines. Not really true dual exhaust tho
Old Jul 4, 2007 | 11:54 AM
killa b's Avatar
yea one line in two out but im not to worried about haveing true dual exhaust its more for looks.
Old Jul 4, 2007 | 12:01 PM
keithguts's Avatar
Do you think this will give better perforamce as well?
Old Jul 4, 2007 | 12:12 PM
FrmrJPGuy's Avatar
You should be able to use that muffler and run the pipes like you want to but if the pipes coming out are 2.5" or bigger you may lose low end torque but you should see an increase in the upper end.
Have you heard what this muffler sounds like?
Your best bet would be to just get a single 2.5" inlet and a single 2.5" outlet muffler that flows really well.
Old Jul 4, 2007 | 12:27 PM
killa b's Avatar
i still have the 3.0 exhaust on the veichle so i should gain some performance. its a glass pack designed muffler so its goin to flow great. also ive thought about blocking one of the tubes which i dont think will matter.
Old Jul 4, 2007 | 12:58 PM
91muddog's Avatar
i would keep both tubes on.
it will sound amazing with the 3.4
you shouldnt lose any power at all since the pipr before the muffler is smaller.
Old Jul 4, 2007 | 01:22 PM
Jay351's Avatar
go with a duel 2.25" out the back of that muffler (if you can)
Old Jul 4, 2007 | 01:58 PM
killa b's Avatar
yea ive got endless posibilties with this setup cause i have to go and get the system completly custom. so if anybodys got some ideas let me know thanks.
Old Jul 4, 2007 | 02:07 PM
91muddog's Avatar
i would do the 2.5 as you mentioned, high flow cat, and i like your idea of dumping the duals before the wheel.
Old Jul 4, 2007 | 02:23 PM
killa b's Avatar
yea i think it will be a good sounding exhaust. it should look good to.
Old Jul 4, 2007 | 02:47 PM
Kaydon's Avatar
Run just manifold
Better performance than a muffler can give ye.
Old Jul 4, 2007 | 02:57 PM
toy4whatever's Avatar
I had a flowmaster 40 series and 2.5 duals ran out the corners on my '90 3.0. It was one in and two out just like what you have there. Sounded great. You will like it.
Old Jul 4, 2007 | 08:50 PM
killa b's Avatar
oh yea ill go and run my exhaust right out the hood itll be kool and give me like 100 more hp just like red stickers and muffler bearings. do you have any pics of your exhaust thanks.
Old Jul 4, 2007 | 09:33 PM
the_gunslinger's Avatar
pipe size in the headers (manifolds) is relevent to torque. you should lose some backpressure if it's an aftermarket muffler, but that might give it an unnoticable amount of top end. if it's too loud, it'll sound like ▓▓▓▓ (v6's fault)
Old Jul 5, 2007 | 03:53 AM
killa b's Avatar
theres already a cherry bomber on it which is straight through muffler just like the magnaflow.
Steven.m.paulk
Jun 7, 2020 10:45 AM
the_supernerd
Oct 1, 2015 09:20 PM
voiddweller
Sep 28, 2015 11:21 PM
Keithstoyota
Sep 27, 2015 07:29 AM
