squeeky noises
Old Jul 16, 2007 | 10:51 AM
Avenged's Avatar
squeaky noises
hey latley my 91 toyota 4x4 has been squeeking or chirping like a bird when i put it into reverse and pull the clutch out to friction point but when its pressed in it dosnt squeak anymore and it does it a little bit in first when im accelerating and more when the engine recoils when i let off the gas. i thought it might be through out bearing in the clutch but when i wash off the drive shaft and the suspension/tranny with the pressure washer it goes away for about a day then it comes back again. any ideas?
Old Jul 16, 2007 | 11:42 AM
drew303's Avatar
Ujoint? ...
The rear spring hangar and shackle bushings could be dry. The bolt will squeak everytime the leaf springs move (axle wrap when you accelerate or decelerate).
Does it feel like the clutch is slipping at all? (engine revs but you dont move as fast as you'd expect)
FYI
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
