- Head Gasket or Rebuild?...
- No pressure in gas tank
- Help with cam
- 1993 P.U. 22RE overheating & losing Coolant
- Bought a junkyard 22re, has water in the oil
- Alignment help: 1993 toyota 4runner 2.4L
- air / smog pump delete. keeping ac
- Quick/easy BJ spacer question....
- 89 rod bearing replacement
- Drowned 4Runner won't run
- AC Liquid Line Tube?
- AC help, I have part numbers.
- AC Clutch replacement?
- What is this?
- Cat bolts
- Time to regear
- New Motor Finished (Well almost)
- Sudden shifting problem (not the shifter seat)
- topper question
- Rear bumper or lift?
- 95 4runner OBD?
- Blower Fan Problem 1987 4Runner
- No high idle when engine is cold
- Jumpy timing California smog question
- 22re quick question
- My brakes are going out!! HELP!! Could it be my master? No leaks!
- regular bed vs. long bed
- Rear swaybar on 1st gen
- pkb cable problem
- bought a 90 pickup have a few questions
- Power window and door lock problems
- hg rebuild
- best topper / cap / camper shell fit on 92 xtra cab?
- 90 p/u suggestions
- Swapping in factory 4.88's and have a few questions.
- ShortMag's 22re Rebuild.
- Block Surface??? check out these pics
- New to toys, yota tech, and the 95 4 runner in my drive!!!
- Im having over heating in my 91 4runner 3l v6. what are possible problems?
- Sheared wheel stud?
- Hoses
- Suspension lift DIY job?? or no??
- high idle & surging with brakes
- Please help! Sputters at low RPM
- Truck lost half its power, please help!
- Idle Down when dipstick is pulled
- Quick help! Is my thermostat opening enough? pic
- Help! My tach went crazy and it brought my AC down with it!
- 22RE Engine Won't Start, Electrical
- Rocker Repair
- New 22re Rebuild won't start. Fuel Pump
- BIG oil leak Help????
- Toyota Red Coolant
- What EVERYONE should know about their truck & the 3VZE
- LSPV Leak
- 1990 4runner up for sale SR5 3.0 1800$
- Rust Repair
- 95 4Runner Rear Window Relay
- Gotta Love That 4Runner
- Required Wiring diagram for 1986 Toyota Reg cab
- Upper ball joint renewal
- TG 3" SAS done.
- Drivetrain vibration question
- 1995 toyota 4runner issue
- 22RE Surfacing
- MPG is dropping, EGR code.
- Brown coolant
- Motor wont spin when rod bolts are torqued
- What type of ATF to use
- Super Rich Crop Duster When A/C On??
- Set the timing/jumpers
- What Do You Make Of These 2 H2O Pumps
- Every time I make a sharp turn, U-turn or simply get out of my drive way I hear this
- 88 efi wont run
- 22RE still overheating after new rad, hoses, and tstat
- Where is the "body ground"?
- Shift question
- help my highbeams stay on and wont go off.
- More power!!!
- Why is my xfer case shifter off
- Is a 22R long block the same as a 22RE
- 87 4Runner SR5 Fuel Gauge Acting Up.
- Auto Tranny Acting Funny
- My New Project!
- Anyone know the exact years of the Altimeter?
- Replacing front crank seal, etc
- '88 runner- sluggish after periods of rain
- Electric fan option's opinion's needed
- Too mant HG jobs on one engine?
- factory R12 a/c install checklist
- manual swap checklist
- converted a 2nd gen grill into my 1st gen
- 02 Sensor Volts Question
- Advanced Timing Issues
- How does a malfunctioning Ignitor Module affect the injectors from firing
- Rear back up lights / Stalling going up hill
- 94' 4Runner oil pan removal?
- A/C information
- 22RE: Touble After An Engine Swap
- 86 4runner questions...
- Removing intake manifold
- Does anyone know of any Toyota mechanics in Powell River?
- Rear coils, there has GOT to be a better way!
- AC died
- T case
- rear window compatability
- 954runner sputters..come and go and now
- Seating position in a 86-89 pickup
- Need help, code 11 and hard to start..
- Something wrong with my pickup extra cab....
- Cant solve Oil Pressure issue, Tried everything??
- wheel bearings?
- how to drop front diff
- where to mount a 10CD changer in a 94 runner?
- questions on a MC front bumper
- creepy problem
- ignition tumbler locked up
- Bone stock '89 runner
- Full tank & changing Filter
- Busted TPS
- 4runner rear crossmember
- help, if it sounds like a rod bearing is it a rod bearing???
- Snorkels and deep water.
- Can a leaky radiator drain plug cause overheating????
- Need Advice on Flowmasters
- Question on Bumpers
- 22ret block
- looking for hid driving lights
- HELP!!!!!!!!!!!! tires balding so fast
- SAS parts interchange
- How do i get the 4wd light to go on?
- Is my transmission bad?
- 3VZE coolant leak
- 22RE build, engine assembly questions
- NWMP aux fuel tank install
- Charge/brake light...then death
- What are you suppose to torque the rod bearing bolts down to?
- my 22re will not run
- 22RE turns over, but won't start..... where to start (no pun intended)
- Driveshaft U-joint replaced, but questions before installing.
- 90 4Runner Electrical issues
- Whirring from the Trans/t-case
- ATTN all AZ yotas! I need help!!!
- Throttle position sensor
- Possible Emission system? Help!
- need opinions on getting road worthy
- Another 3.0 3vze timing belt question
- Just finished painting my rims Check em out!!
- ECU Repairs in Ontario for 3.0TD hilux
- Custom Interior Thread
- arm rest
- Speedo Issue/Question
- Finding the source of a troubling noise- tricks
- Code 27
- dumb 3rd member Q
- Different rear pinion seals?
- 3.0 block surface
- Cragar Soft 8's and 31x10.5 Tires on 95 limited
- 80-140 oil in t-case
- speedo question
- EFI Port and Balance Intake
- shaking at all speeds
- Heading South
- Center pin crap!!!
- Ass sag fix w/o additional lift?
- Locker time!
- Idle issues
- Check engine light
- Interchangable Parts
- What do you have armored on your truck?
- Should i hook up a relay?
- Identify this bracket
- how do you remove the a/c clutch?
- Hit and run
- Torsion bars through the years!
- Gasket Sealant
- IFS lift now or save and do SAS?
- 93 4runner stalls at idle
- Replaced T-Chain, now Grey OIL!
- 89 Wont Start
- no power...
- engnbldr o/s valves
- Need Help with master cylinder on a 1994 4runner?
- Anyone know EPA Gas Milege for 4runner 94 v6 3vze
- 5" superlift
- Fuel injection Equalized cleaning
- BJ spacers
- code 51 question
- Air Intake ?
- Did I do this ohms test correctly on my coil?
- those running 4.10, 22re, 33s- CHIME IN
- ignition, Truck wont start intermittent
- 89 4runner timing problems
- My 1993 toyota 4runner 4wd wont engage!!??!
- HELP 3vze water / coolant temperature sensor
- 22rte questions
- Oil pressure/Water Temp Sender Help
- Fog Lights
- 2nd gen rear window trim
- Need pictures of Vaccum lines and such.
- Pulley
- Rear R&P install problems
- Engine runs a bit rough
- New timing set. Metal backed guides or no?
- Knock Sensor
- 4 runner took me to 10,000 feet plus
- stock vs addicted bumper weight?
- Duralast Starters
- Got 94 V6 3.0L Valve cover gasket change writeup?
- New 88 P/U
- New to forum. My 87 SR5. ISO Opinions.
- Oil pump gear question
- towing tips
- Tranny dipstick and capacity question.
- Where to buy a radiator?
- abs light
- Air Intake Ducting?
- I had to change out the #1 injector the other day
- 22re Idle issues
- Sloppy front end drive shaft
- best gears for 92 4runner
- 1st Gen. 4Door Conversion
- New Engine Wiring Harness Available 22RE?
- 31 vs 225 tires
- Another rear window thread... please help!
- Water Logged 4runner
- Dust/dirt shield
- MY 1994 toyota pickup 4x4 with 22 re engine is having some issues
- Injector o-ring replacement question
- 22re exhaust bellhousing mount bolts
- Rough at Idle
- Where to Find 22ret Engine Parts?
- New IFS Question
- Light weight pullys
- broken e locker
- Will this fit? Swapping beds
- Shock Help!!
- when i rev high enough i get a high pitched squeel out of my engine
- caliper won't unbolt
- bad cam scoring under oil journals??? DO NOT BUY ENGINES FROM MOTORTIME!!!
- Help! my timing won't advance!
- Stock or Manual hubs?
- NEWB/clutch/exhaust/leaks questions
- 92 4 runner/siezed wheel
- Brakes Lock-up
- New here. stock 87 4runner
- Idle problem
- 95 4runner Headlight Upgrade
- 89 4Runner SR5 Lug Stud Thread Size???
- great 3vze post from toy nation
