02 Sensor Volts Question
Old Jul 27, 2009 | 08:16 PM
Guardian_Saint's Avatar
Can't find the sticky link to the FSM, so asking a question on here... Do anybody esle know how many voltage does the O2 sensor signal voltage read out? Thanks in Advance...
Old Jul 27, 2009 | 08:27 PM
abecedarian's Avatar
It doesn't "read" any volts unless it's warmed up. After that you need to monitor the sensor voltage with a high impedence meter to make sure it swings from about 0.2V to about 0.8V at least 10 times per minute. The sensor should not read a consistant voltage for any particularly long period of time, more than a few seconds, and should spend as much time, on average, above 0.5 volts as it does below 0.5.
Old Jul 28, 2009 | 11:00 PM
Thanks for that. I am giong to buy this EQUUS guage that show how your car will run rich or lean while you drive. Just to have something to look into it... The guage require a 0 to 1 volt only and if its over 1 then I cannot use it. So I will get it and see how it goes from there.
80Truck
Oct 12, 2025 07:25 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
Gevo
Jul 29, 2015 11:15 AM
nonstop
Jul 24, 2015 06:29 PM
88yodabasket
Jul 13, 2015 01:32 PM
