89 Wont Start
Old Jul 23, 2009 | 08:59 PM
guypier's Avatar
Question 89 Wont Start
Im working on an 89 Yota 22re it is throwing two codes 12 and 34 need to know what these are please. Also it is getting good air fuel and spark, the timing is good with new cap and rotor. Any ideas
Thanks
Old Jul 23, 2009 | 09:11 PM
toyota4x4907's Avatar
12:RPM Signal. No NE signal is input to the ECM for 2 or more seconds after the STA turns ON.
Is the starter engaging/cranking engine but its not caching? Or is it just not turning over?
There is no code 34 for the 22re.
Old Jul 23, 2009 | 09:20 PM
guypier's Avatar
the starter engages and turns the motor but does not want to start, the guy said that sometimes its starts and run great, he will then go to the store and come out and it wont start at all, and i think the other code was 32, can you explain code 12 a little more, how to fix?
Thanks so much toyota4x4907
Old Jul 24, 2009 | 05:35 AM
There is no code 32 either. There is a 32 for the 3vze and 3fe. Theres a code 31 for the 22re.
"NE" has something to do with the ignition or something. I dont remember exactly. Search around I know it has been explained before. I have to go to work.
Old Jul 24, 2009 | 07:06 AM
guypier's Avatar
sorry toyota4x4907 the guy just called me and said the code was 24 unless he cant count, ill probably look at the codes again thank you
Old Jul 24, 2009 | 03:33 PM
Code 24 is Intake Air Temperature Sensor Signal. Open or short in the intake air temperature sensor for 500 m. sec or more.
Trouble areas: Open or short in intake air temperature sensor circuit, intake air temp. sensor or the ECM (least likely).
Are you sure the timing is set correctly? I dont believe 24 would prevent it from starting, but 12 could im pretty sure. How did you check for good spark?
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
