Need pictures of Vaccum lines and such.
Old Jul 23, 2009 | 11:18 AM
ohyeahcrx's Avatar
Ok so I cant seem to figure out what lines go where. Is there any soft lines that hold fuel? Or are all the fuel lines hard lines and or have those special fittings at the end? Cause I seem to have a rather bad gas leak and everything seems to be good. It appears to be comming out by the fuel filter ( or some place like that cause its dripping right on the starter. But I never took the fuel filter off at any point. So it wouldnt be gushing out for no reason right?
Anyways back to the orginal question. There is like a nipple comming straight up off of the EGR by the intake mani. The nipple is right on the neck it seems. But that general area and under the intake mani if you can.
Sorry for all the requests its just I wanna get this done. Ever since I bought this truck its been a lemon. Never really driven it. Had it for a year. I NEED TO DRIVE THIS! haha
BTW its a 1988 pickup 22re
Old Jul 23, 2009 | 11:58 AM
93YotaGuy's Avatar
Some softlines leading to the fuel filter are soft but they all should have the fitting on them. Did you check for those little washers that should be on the filter lines connecting to it?
If they are not in it could cause a leak. Check it out.
Also their is a fuel line on the top of the pendulum. Could be leaking from there
Hope this helps
http://media.photobucket.com/image/2...s/41758298.gif
Old Jul 23, 2009 | 12:00 PM
yoterr's Avatar
heres a post on here with some good photos...https://www.yotatech.com/forums/f116.../#post50782051
Old Jul 23, 2009 | 12:03 PM
yoterr's Avatar
and another i just found, its about removing egr but has lots of pics of vac lines https://www.yotatech.com/forums/f116.../#post50971807
Old Jul 23, 2009 | 12:13 PM
ohyeahcrx's Avatar
Yoterr- Thanks. But the first link is for a 3.0 so that doesnt do me much good. Unless they are infact the same??
Yotaguy- yeah Ive got the FSM and that diagram and maybe you can see the nipple on the neck of the EGR valve and where the hose goes. Cause I surly cant haha.
Old Jul 23, 2009 | 12:15 PM
iamsuperbleeder's Avatar
I'm willing to bet it's the fuel return line coming from the pressure regulator...
sorry, no pics though
Old Jul 23, 2009 | 12:35 PM
ohyeahcrx's Avatar
Is this the regulator? And is that vacuum hose right? It looks a little long for that application but is it right?
And then the nipple without a hose on it. I just need guidence.
Old Jul 23, 2009 | 12:55 PM
yoterr's Avatar
mt bad i just looked for pics real quick on goooooogle
Old Jul 23, 2009 | 12:58 PM
ohyeahcrx's Avatar
haha No worries man. Thanks for your input though!!
Old Jul 23, 2009 | 01:19 PM
yeah that's the return line, and you've got it right...
nevermind
Old Jul 23, 2009 | 01:27 PM
ohyeahcrx's Avatar
haha atleast I got something right! So I can still test the 2 terminals to see where it is leaking from without the top of the intake mani on right? Jump terminals B+ and Fp and see if theres any leaks? ( dont quote me on those terminals. I can easily find it out though.) and Bleeder your remember the thing I PM'd you about and you said first it was the idle control thingy thats on the bottom of your throttle body? Well thats what it is not the PAIR system. From 89 on they joined it onto the TB. But since mine is an 88 I still dont know where that back hose goes.
Old Jul 23, 2009 | 01:30 PM
4Crawler's Avatar
Yep, that is the fuel pressure regulator and that top nipple needs a hose connected to the intake manifold for vacuum:
http://www.4crawler.com/4x4/CheapTri...ine_Pix/8.html
Old Jul 23, 2009 | 01:42 PM
ohyeahcrx's Avatar
Yess 4crawler thank you. The hose I need is the one on the neck of the EGR valve. But since you eliminated the EGR ha oh well.
Old Jul 23, 2009 | 01:48 PM
4Crawler's Avatar
I still have the EGR valve and all it's plumbing on my engine.
Old Jul 23, 2009 | 01:59 PM
ohyeahcrx's Avatar
Oh you do? Can you tell me what goes on the EGR valve neck? Comes right off the head then before the gold top theres a nipple. what goes there?
Through my research I found this
https://www.yotatech.com/forums/f2/v...-pickup-70536/
And this is correct right? Can some one confirm this?
Old Jul 23, 2009 | 02:41 PM
4Crawler's Avatar
Top of EGR connects to a hard line that runs up to the BVSV under the throttle body in front of the intake. That is what opens/closes the EGR. Check out the EC (Emissions Control) section of the FSM for details.
Old Jul 23, 2009 | 02:50 PM
ohyeahcrx's Avatar
Yes I know where the top of the EGR connects just not where the nipple on the Neck of the EGR valve. Where is the EGR-VM?? Cause in that diagram, post #15, it says it connects to the EGR VM
Old Jul 23, 2009 | 02:56 PM
4Crawler's Avatar
Bottom side of EGR connects to the bottom of the EGR modulator.
Old Jul 23, 2009 | 03:06 PM
ohyeahcrx's Avatar
Oh alright. And which item is that??
Old Jul 23, 2009 | 03:14 PM
4Crawler's Avatar
The round thing that all the EGR related vacuum hoses connect to; far right center of the picture below:
