Finding the source of a troubling noise- tricks
Old Jul 24, 2009 | 09:06 PM
Matt16's Avatar
How would I find where a creaking noise is coming from? I am thinking about spraying each bushing, joint and connection in my front suspension one at a time with WD40 to find the source of a creaking noise I have.
Might as well add, due to the title of the thread:
how to find and exhaust leak
Take a couple feet of garden hose or 1/2" fuel hose, put one end up against your ear, and move the other end around the exhaust system- when you near the source of the noise, it will sound very distinctly like a helicopter. It is very easy to find exhaust leaks with this method.
Old Jul 24, 2009 | 09:13 PM
shftatsix's Avatar
also soapy water poured on the connections will produce bubbles at leak (dont pour on a hot engine )
Old Jul 24, 2009 | 10:13 PM
desertcamper67's Avatar
I would use something else like silicone spray on your rubber bushings. Nothing petroleum based. It breaks down rubber.
Another thing you might try is have someone walk along your rig while you run over some bumps and recreate that creak. They might be able to at least pinpoint what area its coming from.
Old Jul 25, 2009 | 12:55 AM
abecedarian's Avatar
Is it possible to give any less information?
Synopsis: "How can I find the source of a creaking noise?"
Well....
If it does it when you turn the steering wheel: the ball joints, tie rod ends, etc. (everything that moves when you turn the wheel) need inspected as well as the steering pump, belts....
If it does it when you're rolling: wheel bearings, brake pads, calipers....
If it does it when you hit bumps: upper / lower control arm bushings, ball joints, sway bar end links or frame mounts.
If you're standing still / not moving: the truck is posessed.
Old Jul 25, 2009 | 01:36 AM
Matt16's Avatar
Already found the source of this particular. I was more interested in the process than the result here.
The heim joints I use for sway-bar endlinks (quick disco's) had loosened off a bit allowing some play the heim joint and the sway-bar. The other side has a bent IFS bracket than makes contact with the LCA by the bushings. The noise is silenced by rain and lube.
Hamonacracker
Jul 17, 2015 08:33 AM
razorman8669
Jul 12, 2015 12:13 PM
shar
Jul 9, 2015 12:38 PM
cyclist231
Jul 7, 2015 12:56 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
