LSPV Leak
Old Jul 29, 2009 | 08:03 AM
McQuaid's Avatar
LSPV Leak
Hi Guys
Ive a leak in my LSPV so it needs immediate fixing....i have been looking for one for quite some time and am having trouble finding a reasonably cheap one, ive seen some "alternative" options, a manually adjustable one but it doesnt look the same at all and supposedly you can fit it in engine bay as opposed to rear axle?? how does that work?? what do i do with my hoses that go to LSPV???
Cheers again guys
Mark
Old Jul 29, 2009 | 09:00 PM
RobD's Avatar
I pulled mine out and removed one of the two lines feeding it, ran a new line for the rear brakes, and was done with it. No manual proportioning valve, but you could add it to the line coming off the master cylinder if you wanted to.
If you find yourself in Calgary, Alberta, Canada at some point, you're welcome to come take a look
Old Jul 30, 2009 | 12:19 AM
McQuaid's Avatar
you see mines leaking so it needs to be renewed : ( i reckon im looking at big bucks here : (
Old Jul 30, 2009 | 06:59 AM
McQuaid's Avatar
have just ordered a stock toyota one off fleabay, secong hand but not leaking for $45 delivered to ireland...best deal i could have asked for
Old Jul 30, 2009 | 02:52 PM
sh0kk86's Avatar
where was it leaking from?
im haveing a problem with my brakes, and i cant find a leak anywhere else
Just redid my front brakes, rear brake lines, my mc isnt leaking, but still air is gettign in.
i think it may be the lspv, i need to get rid of the stupid thing. i cant find the right height anyways to keep the rearend happy. its either to low and the drums dont do any work or its to high up and it locks them up to fast.
Old Jul 31, 2009 | 12:11 AM
McQuaid's Avatar
just infront of the rear axle is where the lspv is located, there is two lines coming out of it facing frintwards, the top one of them is leaking, once i see my lspv, i can see the leak so if you can see it then if theres a leak, you'll see it
Old Aug 7, 2009 | 02:41 AM
McQuaid's Avatar
ok new lspv arrived...so i attempted to take off old one....and WOW.....those brake hoses do not want to come off! anyone any tips?? i heated them...tried a spanner, no joy so tried a vice grips and still no joy....in a bit of a pickle on this one
Old Aug 7, 2009 | 06:07 AM
RobD's Avatar
Hopefully you didn't round the nuts with the spanner or Vise Grips.
You should use a good quality penetrating oil like PB Blaster. Let it soak in for a day or two, spraying a couple times. And you should be using a proper flare nut wrench, as they are designed to grip the nut without rounding it off.
That's how I got mine undone.
Old Aug 7, 2009 | 06:20 AM
Lumpy's Avatar
2X on this one! Before I start any job and there is a bit of rust on them I always PB Blaster them for at least 2 days before I start. got tired of replacing and cutting.
Old Aug 7, 2009 | 06:41 AM
WatsonToyota's Avatar
a lot of PB blaster and a big pair of vice grips, work (wiggle) the fittings slowly back and forth as to not cut thru lines, then more pb blaster. flare nut wrenches are good but u can usually get more torque out of the vise grips...... i went to the junkyard three days ago and asked them for LSPV for 86-95 toyota and fella said "oh we don't have any of them (toyota's) here." i could see two pickups within a stones throw of their shop!! unreal, ppl around here are still hung up on american motors and "muscle" cars to the extent that they won;t even work on "them toyota's", unreal!! goodluck, brakes can be a PITA
Old Aug 14, 2009 | 07:12 AM
McQuaid's Avatar
ok guys, ive had no luck with this, ive been able to work 2 of the connections loose but no joy with the 3rd, the 3rd is only a short one thats fitted to a flexi hose just infront of the LSPV so im gonna replace that hose, can anyone help me to locate this hose?? i tried that toyotadiy parts catalogue but cant een find the LSPV on it????
Old Aug 14, 2009 | 06:07 PM
RobD's Avatar
I got mine from NAPA. I doubt you have many NAPA stores on the Emerald Isle.
Old Aug 15, 2009 | 03:20 AM
McQuaid's Avatar
i dont even know what a NAPA store does
he's gone
7
Dec 3, 2019 07:08 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
87turboPA
Jul 12, 2015 07:49 AM
Avenged
Jul 9, 2015 07:55 AM
87turboPA
Jul 9, 2015 05:58 AM
