PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Leaking oil from the axle, need recommendation
  2. Changed up my paint a little today.
  3. coolant overflow
  4. '95 Pickup stopped working (electrical) entirely
  5. Manual transmissions: 4-speed vs 5-speed
  6. Carb Options: Rebuild, Remanufactured, Weber, etc
  7. toyota truck hard to start
  8. 93 Pickup Lift Advice?
  9. '87 turbo 4runner brake system compatibility
  10. Dash relay?
  11. Engine swap or rebuild?
  12. 88 pickup R12 A/C recharge questions?
  13. Missing rear driveshaft ,1986 4x4
  14. First 22RE, could use some help with stutter and dying at idle
  15. 1st gen 4Runner custom center console
  16. 1992 toyota pick up 22re reg cab sb
  17. Strange ticking noise on driver's side 3.0
  18. 5VZ-FE fuel injectors in a 3vze ? vs aftermarket
  19. swapping 3.0 for 22ret
  20. 1993 Toyota Pickup 4X4 Steering Clunk
  21. 93 Pickup Tailgate Lock?
  22. Quick question - oil pump through-bolt length?
  23. Recent 3VZE Rebuild - power issues
  24. Help! OBD 42 43, busted speedo and odo, wandering idle.
  25. Auto / Manual hub swap
  26. What shocks to get for a 2nd Gen?
  27. 4Runner Body Removal/rust repair question
  28. Advice on crankshaft replacement
  29. Not sure where to post but need help ASAP: 87 4x4 with 88 22r running issues
  30. 3vze pinging nightmare
  31. When to do a diff rebuild
  32. 3vze stutters while driving
  33. Creaking sound when releasing clutch?
  34. 86' Runner leaking near the transfer case
  35. 2in body lift with 33s?
  36. Rear window switch wires
  37. Wiring Harness Cut
  38. 22RE Oil Galley Plugs
  39. Major idle/ running problems on 3vze
  40. 22RE Hard Warm starts
  41. Horn wiring problem
  42. coolant leak under the throttle body-1987 Toyota 4runner
  43. I can't find a waterneck/thermostat housing for my 1986 22r-te pickup
  44. 3vze Spring type tensioner
  45. Putting 16 inch tires on 92 pickup 4wd
  46. Diagnose this weird sound?
  47. Lift
  48. 87 4Runner Seats
  49. What is this part number
  50. Intermittent starter problem
  51. Average Time Needed to Swap Engine
  52. Oil Pressure guage
  53. Starter removal 1986 Toyota truck
  54. 86 yota on long road trip?
  55. 88 pick up wont stay running
  56. 1st gen Plastic Grill Clip 3D Model
  57. Clutch replacement on 93 (fine details)
  58. 22re rebuild plus some
  59. 2 more questions
  60. Vacuum (?) lines and missing parts - please help!
  61. new Exhuast
  62. Headlamp Question
  63. Research
  64. Code 12 and Code 52
  65. 2nd generation stock ride height
  66. 22re "fires" wont run. Whines
  67. NO BRAKES. Help!!!
  68. 10.5 vs 12.5?
  69. 3vze o2 sensor issues with new sensor; maybe ecm issue?
  70. Working with the tps
  71. starter flywheeel issues?
  72. Any YotaTech Guys at Fort Irwin CA or close.
  73. cab differences from 2wd-4wd
  74. Best Tire size for a stock 91 pickup
  75. Pinion gear and/or differential messed up... or is it?
  76. Are ENGNBLDR Timing Kits still good?
  77. 90 Toyota pickup front grille
  78. 90 Toyota pickupheadlight adjusters
  79. engine bogging
  80. Help me Please, Trans issues
  81. I need help.
  82. Can I install lockouts?
  83. Still No Power Steering! Need help
  84. 1995 4runner 170 thermostat part number
  85. Knock sensor signal
  86. 22RE timing cover - all bolts out, breaking it loose?
  87. engine build estimate
  88. 95 4runner 22RE overheating !!!
  89. 94 22re hesitates
  90. isuzu dana 44 or isuzu corporate 12 bolt
  91. temp gauge ??
  92. Princess Auto Buyers Class 3 Hitch
  93. How do you unStick a Brake Caliper
  94. Timing Advance - advice needed
  95. Drinking gas and smelling like it.
  96. 1992 toyota pickup speed problems
  97. 22RE no hot start
  98. Southern Oregon Yota Owner
  99. New here
  100. New to YotaTech with a new truck
  101. New to YT...
  102. Idle demons that I need help with (video inside)
  103. Buying new leaf springs for the rear need help deciding
  104. Need Help - bought 87 yota discovered leaking fuel and starting problem
  105. wheels, wheels, WHEELS
  106. 22RE valve adjustment hot or cold?
  107. need help!!!!!
  108. freeze plug leak in the back of 3VZE
  109. Radio in a 86 yota
  110. engine code confusion
  111. Por-15 on bumper..
  112. I have 3 question
  113. A couple general questions about my truck.
  114. clear my mind for me
  115. Do gears myself or pay a shop?
  116. 95 Pickup More interior Light
  117. Swap engine or just get rid of it?
  118. Are head gaskets specific to bore size?
  119. how good does the 4x4 work
  120. First Gen Satoshi grille?
  121. Shocks question
  122. 1993 4x4 Pickup Leaf Springs or Zuk Mod?
  123. 22re clutch in an 86 4Runner
  124. Power Steering Issue Help!
  125. Plastic Screw Grommet
  126. new timing chain problem
  127. 22r to 22re
  128. Crankshaft pulley bolt/Seal.... is this okay?
  129. Broken bolt on Knuckle Arm
  130. Help! 87 4Runner only runs good w/ Advanced Timing!
  131. 87 4runner FOR SALE
  132. 3vze 3.0l hi-pro v6 engine ?¿
  133. How much R12 does 86 toyota pickup hold? Just installed AC.
  134. Splash guards
  135. cylinder bore specs?? rebuilt ATK??
  136. A/C compressor isn't turning on after A/C install system is not charged yet?
  137. Radiator Question
  138. the question-22re or 22rte?
  139. Steering column help
  140. Gear pattern check
  141. Vibration thoughts??
  142. 91 toyota truck 22re smokes under load
  143. Toyota 3.0-vze engine not firing after rebuild
  144. Lift kits and Tires
  145. Where to find: MANUAL rear window regulator 1st gen 4Runner???
  146. 1988 4x4 22RE strange issue.. any hints?
  147. Surging 22re toyota pickup
  148. 89 22re rebuilt NEED vacuum line diagram
  149. This my Yota
  150. how fast can I go in 4wd with rf1a gear driven transfer case?
  151. 86 22r pickup losing power while accelerating
  152. 94 3.0 defrost not working that well
  153. long travel suspension question
  154. 91 22RE Knock Sensor Wire - Where is it?
  155. Shocks
  156. New member/cigarette lighter outlet question
  157. Coolant leaking from new Permatex
  158. 91 3VZE tune up questions
  159. Intake manifold and fuel injectors cleaned/reinstalled but now she wont start!
  160. Check it out
  161. Leaking AS Reed Valve question
  162. 1993 and later spark plug wires?
  163. 22RE Dies when splashed by puddles
  164. Anyone have a VSV for my A/C that will work with my 1986 Toyota Pickup?
  165. what does an 86 weigh
  166. Help with wire identification
  167. Frustration! Head gasket or intake gasket
  168. Another head question
  169. 1988 4runner
  170. Where find aSupercharge for 22re?
  171. Jeep springs and shocks Zuk mod
  172. 1992 toyota 4runner - water temp guage not working
  173. 92 toyota 4runner corner lights. fitment
  174. Front LockRight Installed on IFS
  175. Fuel injector problem? tell me it will be ok
  176. cCamshaft position not found?
  177. Help! i cant figure out one little thing
  178. Can anyone tell me what this is?
  179. WTK: Trying to decide on header 22re..
  180. "diagnostic test mode" Help with pinpointing bucking/surging issues
  181. high beam problems... need help locating a ground.
  182. Truck won't pull
  183. ES9000 shocks wont fit??
  184. 3VZE Oil pressure question
  185. 1991 yota brake issues
  186. 86 22re issues...
  187. LCE cam prior to or after new engine break in?
  188. Whistleing noise after clutch kit...
  189. Vin # diving me crazy
  190. 93 yota 4 cylinder
  191. Manual Steering Box
  192. Cruise control actuator question
  193. Broken leaf spring help
  194. 92 22re auto 4x4 buzzing in trans pan?
  195. Removing heat from the engine bay 3vze
  196. 1986 22r pickup with bad head gasket and maybe rod broke??????
  197. How many miles do you have on your 3.0?
  198. Will runner door fit a P/U??
  199. Leaf Spring Replacement
  200. Funky Idle
  201. 94 sr5 3.0 truck wont go faster than 65mph
  202. 22re header, 2wd vs 4wd
  203. Fuel system woes again
  204. Head Gasket diagnostic
  205. For sale?
  206. sell as long block or part out?
  207. Need suggestions!
  208. ID these fender flares
  209. Grinding noise with hubs locked.
  210. Iac
  211. Side stripe/graphic removal?
  212. 1988 toyota truggy
  213. 1994 toyota sr5 ext cab 3.0 v6 at warm up runs ˟˟˟˟ty
  214. Bad dizzy maybe? So freaking confused!
  215. 95 Toyota Truck Wiring harness problem
  216. 1991 Speedometer cable removal
  217. Autotragic linkage adjustment?
  218. Steering system issue
  219. Tailgate help!
  220. D.I.Y. Bedliner?
  221. Carrier bearing size
  222. Truck won't start after it ran out of gas
  223. 2009 tacoma seats :)
  224. 22re Tick and Bad Looking Sparkplugs
  225. So the sensor I just broke, what is it...?
  226. Replacing rear bumper on 1987 4Runner - Need help identifying parts
  227. 89-95 IFS Trucks With 37" Tires... Completely Confused.
  228. 22re valve adjustments
  229. Will 86 Pickup 22RE A/C system fit in my 86 22R Pickup???
  230. 1990 4Runner Seats
  231. 1990 4Runner Seats
  232. blown head gasket!!
  233. Advice!!!!
  234. tachometer
  235. Sudden, put tranny in gear and acts like it's in neutral
  236. Burping or Bleeding Coolant Question
  237. Will it look stupid?
  238. 1989 (?) Constant overheating!!!
  239. emission question for a weber
  240. Interior and speaker.. update
  241. 94 v6 4runner starts but shuts off after 1 minute
  242. Looking for A/C System for 1986 pickup any input on what years will work also.
  243. W56-E gear oil change question
  244. 3VZ-E Valve Shims for Sale
  245. Help with eng problem
  246. 89 yota speaker replacement
  247. 86runner quirks
  248. Metal in rear diff
  249. rust and rot frame
  250. Gear ratio?
