22re "fires" wont run. Whines
Old Apr 8, 2014 | 07:26 PM
YotaSnap's Avatar
I replaced the head gasket on my 87 runner.
22r with efi attached.
If I mess around with the distribution, it will either run for a few seconds and then die or it just won't fire at all.
Either way, there is a strong whine coming from in or on the motor.
It acts like a miss fire, it has spark and fuel.
Belts are okay, valves are adjusted.
Help me and the truck to stop whining please!
Old Apr 8, 2014 | 08:36 PM
Killgore Trout's Avatar
Video with audio? Stethoscope? any oopses durring HG job? need more info.
Old Apr 9, 2014 | 07:05 AM
thefishguy77's Avatar
If compression is good across the board. Could it be off a tooth on the dizzy gear? Not sure it would even run. Air/vacuum leak? I have had one on the back of the plenum before. The more information you give us, the easier it is to help you.
Old Apr 9, 2014 | 07:54 AM
scope103's Avatar
"whine" is often the distributor. You can use a fancy-pants stethoscope http://www.harborfreight.com/mechani...ope-69913.html , but I've had good luck using the tube inside of a roll of paper towels.
You DO have the induction all hooked up, don't you? If you don't have air running through the VAF, the fuel pump only runs with the key turned to start. Once you let go of the key the pump will stop (air flowing through the VAF keeps the pump running).
Sep 4, 2015 09:27 AM
AppalachianOffRoader
Aug 11, 2015 01:15 PM
norcal98
Aug 10, 2015 06:20 AM
Jonny246
Jul 24, 2015 12:37 PM
mengquis
Jul 13, 2015 10:39 AM
