Knock sensor signal
Old Apr 6, 2014 | 02:30 PM
hypermax's Avatar
Knock sensor signal
http://s1144.photobucket.com/user/hy...tml?sort=3&o=1
the first pic is me testing continuity on the pins and only the one pin comes up with 0 the other one i get nothing no power or ground just dead
http://s1144.photobucket.com/user/hy...tml?sort=3&o=2
the second pic is the wire from the plug and the color is grey, and for the life of me i cant find that wire on the ecm plugs. does the wire go to a junction or turn into a diff color that would go to the ecm plug? im thinking of running a test wire from the plug once i find out the pin for the knock sensor signal wire and would i just splice it into the gray wire on the plug?
Old Apr 6, 2014 | 04:01 PM
INFINITY's Avatar
http://personal.utulsa.edu/~nathan-b...ne/44engin.pdf
dont forget the knock wire is a insulated wire like a tv coax cable. do a search for knock sensor rewire on google
Old Apr 9, 2014 | 02:23 PM
hypermax's Avatar
checked the wires and they are all good im guessing the ecu is fried, is their a way to fix the pin in the ecu my self or is it time to look for antoher ecu
djohnson13
Sep 4, 2015 12:35 PM
raptor510
Aug 19, 2015 02:15 PM
Flossy
Aug 5, 2015 05:14 PM
nonstop
Jul 24, 2015 06:29 PM
