Knock sensor signal
Knock sensor signal
http://s1144.photobucket.com/user/hy...tml?sort=3&o=1
the first pic is me testing continuity on the pins and only the one pin comes up with 0 the other one i get nothing no power or ground just dead
http://s1144.photobucket.com/user/hy...tml?sort=3&o=2
the second pic is the wire from the plug and the color is grey, and for the life of me i cant find that wire on the ecm plugs. does the wire go to a junction or turn into a diff color that would go to the ecm plug? im thinking of running a test wire from the plug once i find out the pin for the knock sensor signal wire and would i just splice it into the gray wire on the plug?
http://personal.utulsa.edu/~nathan-b...ne/44engin.pdf
dont forget the knock wire is a insulated wire like a tv coax cable. do a search for knock sensor rewire on google
djohnson13
Sep 4, 2015 12:35 PM
Flossy
Aug 5, 2015 05:14 PM
