Major idle/ running problems on 3vze
Old Apr 12, 2014 | 10:28 AM
solidaxle85's Avatar
So i tried to do some searching around, but everything i read doesnt sound
like the problem i have.
so i got my new 3vze in new headgasket and such
When i start it up it has lots of trouble starting sputters around at 2-300 rpm
then it catches and goes up to like 3500-4000 then goes down to a 2000-2700
rpm idle i fixed a vacum leak at the throttle body, now im just stumped. dont even
know where to begin should i back the timing off, i'd like to be able to know how
to adjust the tps but i dont know if that is the problem but it could be
When i drove it i would start going and give it gas and the truck would just keep
giving me throttle and then i would shift gears and the rpm would just go up to
5k rpms sometimes.
don't even know any help would be macho aprechiato
Old Apr 12, 2014 | 12:03 PM
oldblue's Avatar
get some brake or carb cleaner and with the engine running spray it around the intake and vacuum lines. if idle changes, you have a leak. don't spray it on or near the distributor cap, or flames will result.
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
