93 Pickup Lift Advice?
Old Apr 15, 2014 | 07:50 PM
david93yoter's Avatar
Hey guys.
I want to lift the rear of my truck about an inch as i don't like how it sits a little low in the rear. What would be the best way to do this? I was thinking blocks but I couldn't really find any blocks smaller than 2 inches. Any better ideas? The front is stock and I want to keep it near level. I'm still pretty new to 4 wheel drives so I'm sorry for any stupidity here.
Thanks
David
Old Apr 16, 2014 | 05:54 AM
rattlewagon's Avatar
Is it settling because your springs are old? New springs would be the best fix. Could add longer shackles. Also search add a leaf and the ZUK mod. Lots of options out there.
Old Apr 16, 2014 | 06:09 AM
wanayota's Avatar
An add a leaf is the easiest but it will wear out and warp your springs in the long run. Longer shackles also put the springs at a different curvature and therefore a different load so it could mess them up too. New lift springs are the way to go.
Old Apr 16, 2014 | 06:33 AM
meisentones's Avatar
If it is just a slight sag...add a leaf is the easiest and cheapest. I've been real happy with mine from Pro Comp, but new leaf packs are indeed the best option.
Do you have a topper or something causing a heavier load in the back?
Old Apr 16, 2014 | 07:40 AM
wanayota's Avatar
93yoter...dont get me wrong an add a leaf isnt going to ruin anything really quickly. In my 89' 4Runner i run a 2.5in Pro Comp add a leaf in the rear on top of a 6 inch rough country lift and in all my wheeling i never had any problems with it. Other than the one time my leaf pack bolt snapped and it started twisting out of the pack 😁
Old Apr 16, 2014 | 08:19 AM
highonpottery's Avatar
For minor butt-sag I would go with either an add-a-leaf or extended shackles like stated above. Add-a-leaf kits can be found as low as maybe $30 new. For shackles, it's 1" longer for every 0.5" height gain. Stock is 3.5" eye to eye. Shackles should be well under $100 for a set with new bolts and bushings. If you want more height, a proper leaf swap is the fix - these run around $300/pair for something like OME leafs. Good luck!
Old Apr 16, 2014 | 12:08 PM
Does the add-a-leaf hurt the articulation or ride at all? I was trying to find longer shackles but I couldn't find any but tacoma shackles. I'll eventually just get new leaf packs as it sounds like the best way to go. Thanks for the help guys
Old Apr 16, 2014 | 12:31 PM
If you are saggin, and you install an add-a-leaf, if you get the correct size, it should bring you back to stock height. So not affecting articulation or drive characteristics....except for some slight to moderate stiffness.
Old Apr 16, 2014 | 05:29 PM
Alright thanks for the help guys!
Old Apr 16, 2014 | 06:01 PM
dropzone's Avatar
Fossilized
read this:
https://www.yotatech.com/forums/f116...tickys-242840/
icentropy
Sep 16, 2020 02:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 8, 2015 12:05 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
