starter flywheeel issues?
Old Apr 8, 2014 | 11:33 AM
John101477's Avatar
having issues figuring out the sound of a new starter I put in. it looks like the top of the spindle on the starter is rubbing against the flywheel. the old strter was worn down by nearly an 1/8 inch and the new starter makes a horrible sound as if it is not disengaginging . took it off and it is starting to wear in the same way
Old Apr 8, 2014 | 11:34 AM
John101477's Avatar
trying to post an image of what is happening looks like I have to open a photobucket again
Old Apr 8, 2014 | 11:37 AM
John101477's Avatar
Old Apr 8, 2014 | 02:29 PM
Rowdydudeman's Avatar
it could be as simple as loose tranny bolts.
Old Apr 9, 2014 | 07:51 AM
John101477's Avatar
yeah replaced the starter as it had broken stuff in it but still have a sound coming from that area. My father in law seems to believe it might be the flex plate (86 automatic)
Old Apr 9, 2014 | 08:02 AM
John101477's Avatar
Which is easier to get out the tranny/transfer or the engine?
Old Apr 9, 2014 | 03:00 PM
catfish_hunter's Avatar
I just dropped the tranny/case in mine... its a PIA unless you have plenty of clearence and a tranny jack and a good hard surface to work on... Don't do it in your yard on a sheet of plywood haha....
I'd pull the motor out before i tried that again.
Old Apr 10, 2014 | 05:46 PM
DrCreosote's Avatar
I had that problem with a replacement starter and bought a shim kit from Autozone to fix it. I used the thinnest shims first and that problem went away.
Old Apr 10, 2014 | 07:08 PM
881stGenRunner's Avatar
if the shims DrCreosote suggested do not work and you decide to drop the tranny or pull the motor, i would totally go with the transmission. up to you though
Old Apr 11, 2014 | 12:28 AM
wyoming9's Avatar
Red face
I think this is a case of a loose flex plate and poor quality of China made starter parts.
Old Apr 11, 2014 | 05:21 AM
John101477's Avatar
well the flex plate is not just loos it is broke. I finally found the crack and will be dropping the tranny today. Not real thrilled but I know I have to get it done. The first replacement starter had the bendex sticking out to far so I got a different one and it actually fits but now that I found the crack in the flex plate it is what it is.
Old Apr 15, 2014 | 04:12 PM
John101477's Avatar
Ok so I have the tranny out and 5 of the 6 bolts out. Last bolt is being a pita. Quick question. Why is the new flexplate not have uniform bolt holes? The flywheel for the man is basoc 6 holes all even but the pattern for my atm is not uniform.
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
mluz013
Aug 2, 2015 05:00 AM
clok
Aug 1, 2015 09:42 PM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
