3VZE Oil pressure question
Old 03-28-2014, 07:48 AM
GrizzlyMan660's Avatar
Old 03-29-2014, 07:36 AM
Marc's Avatar
That's fine. Oil pressure is dependent on engine revs, viscosity and temperature.
Old 03-29-2014, 08:09 AM
nMe_814's Avatar
Yes like marc said, it depends on rpm. At idle it should be between the middle mark and all the way to the left, and at higher rpms it should be between the first and third marks. So at 2500 you look to be ok past that first mark but I would definitely put 10w30 or 10w40 in it.
Old 03-29-2014, 08:21 AM
millball's Avatar
Factory electric sender type gauges are known to be less than accurate.
If you really want to know what your oil pressure is, a quality mechanical gauge will tell.
You can temporarily hook one up to the oil pressure port.
That being said, your pressure is probably OK.
I don't like how low my 2nd gen 3.0 gauge reads, but I've gotten used to it.
Old 03-30-2014, 03:21 PM
put 1040 quakerstate in it with a little stabilizer. great OP now!
Old 03-31-2014, 05:58 AM
RSR
RSR's Avatar
The owners manual has pictures that address this...
But yes, ~1/4 of the is normal when hot and idling.
Old 04-01-2014, 02:22 AM
RSR
RSR's Avatar
Also, the oil sensor is above the oil filter (if yours is front mount) and can be replaced, which would likely result in a more accurate pressure reading...
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
88yodabasket
07-13-2015 01:32 PM
Coreyr384
07-10-2015 11:13 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: 3VZE Oil pressure question
