Dash relay?
Old Apr 15, 2014 | 05:32 PM
Carvey1989's Avatar
Dash relay?
Y buddies 1989 truck the blinkers and the gas gage don't work. I'm thinking it's the dash relay?
Old Apr 16, 2014 | 11:49 PM
wyoming9's Avatar
Red face
What gives you that idea??
Old Apr 17, 2014 | 04:47 AM
92yote4x4's Avatar
my blinkers stopped working and it was just loose connection above brake pedal
Old Apr 17, 2014 | 07:57 AM
Carvey1989's Avatar
The reason I have that idea is because they both quit at once and the blinker light works it turns on but doesn't blink
Old Apr 17, 2014 | 08:14 PM
RAD4Runner's Avatar
By Dash relay, you mean tail light relay? Check your schematic, I do not think Dash relay affects blinkers and vice-versa.
Old Apr 17, 2014 | 08:45 PM
scope103's Avatar
Check the "Gauge" fuse (10A) http://personal.utulsa.edu/~nathan-b.../2powersou.pdf
Replace the Turn Signal Flasher. http://www.autozone.com/autozone/par...=6415_0_11714_
The turn signals are not powered through the tail light relay (as Rad4runner suggests), so your problems are not likely to be related.
Old Apr 18, 2014 | 04:24 AM
RAD4Runner's Avatar
I like that LED-compatible flasher! Thanks, Scope103
Old Apr 18, 2014 | 12:19 PM
Carvey1989's Avatar
Gauge fuze is good
Old Apr 18, 2014 | 12:31 PM
RAD4Runner's Avatar
Originally Posted by Carvey1989
... the blinker light works it turns on but doesn't blink
You mean the turn signal lights turn ON but do not blink? You sure you are not looking at marker/tail lights? Those stay on and do not blink.
Do you hear/feel the belinker relay click?
Do you have a schematic of your trucK?
Bourbonblues
Dec 15, 2017 05:43 PM
pickle6415
Dec 25, 2015 07:34 PM
runnermedic
13
Sep 21, 2015 05:20 PM
zz_denis
Sep 6, 2015 03:43 PM
May-39
Sep 6, 2015 01:05 PM
