Another head question
Old Mar 29, 2014 | 12:25 PM
lululalalu's Avatar
My 88 4Runner 22RE makes gurgling sounds under my glove box and stumbles to start some times.
I presumed my head was blown in a small place between cylinders, but...
I had the coolant system (heat included) and cylinders pressure tested. Everything was fine.
I just drove +900 miles home for spring break using heat the whole way. It used 1/4 gal of coolant.
Then I drove +900 miles back not using heat at all, and it used 0.00 gal of coolant.
Oil and coolant are clean (i.e., no mixing)
Any suggestions before I pull the head?
Old Mar 29, 2014 | 01:25 PM
lululalalu's Avatar
Oh, I think mudhippy said to check plugs for coolant (i.e., starting short out stumble) on another thread. I’ve run it with the heat on, let it sit, and checked. They were dry.
Old Mar 29, 2014 | 06:08 PM
lobukbuild's Avatar
possibly just a leak in the heating system?
Old Mar 29, 2014 | 06:35 PM
nothingbetter's Avatar
Is your passenger side carpet wet?
Wash the engine bay well from above and below, then park on your grandmas perfectly clean drive way. Look for any dots of coolant when your done eating her fresh made cookies. A piece of cardboard work too if its not windy.
You can also get a cooling system pump. you hook it on where the rad cap is, pump the system up to pressure and look for your leak.
Old Mar 30, 2014 | 12:42 AM
rworegon's Avatar
Are there any coolant like that feed a rear heater set-up? Gurgling under the passenger side dash is often the heater core talking to ya.
Old Mar 30, 2014 | 02:33 AM
lululalalu's Avatar
I had the coolant system pressure tested, with cut-up boxes underneath. There were no detectable leaks, so they left it under pressure over night. Pressure held.
Old Mar 30, 2014 | 06:24 AM
rworegon's Avatar
How does the oil look?
Old Mar 30, 2014 | 10:15 AM
lululalalu's Avatar
I did a tune-up and oil change before the drive out (which used some coolant) and back (which used less coolant than detectable by placing a piece of duct tape on the waterline on the reservoir).
After the 1800 mile trip, the oil is still amber.
Old Mar 30, 2014 | 05:39 PM
lobukbuild's Avatar
bad radiator cap?
bigjstang
Jun 2, 2025 03:56 PM
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
nonstop
Jul 24, 2015 06:29 PM
Coreyr384
Jul 10, 2015 11:13 AM
