coolant overflow
Old Apr 16, 2014 | 10:46 AM
88y0ta4x4's Avatar
coolant overflow
I have an 88 toyota 4x4 with a 22re. Engine was rebuilt 3 years ago. I have never had cooling issues. At the end of a 45 minute drive, coolant overflows from expansion tank. However, the temp gauge does not indicate overtemp. If its actually overheating it should indicate as such.
My first try i replaced the radiator cap and filled radiator. let engine warm up and bleed air out then cap the radiator. I drove to work just fine, no overflow, then on return trip it overflows.
Oil level indication seem fine with no coolant visible on dipstick as i was afraid of blown head gasket. I would replace the thermstat as a troubleshooting step, but my temp gauge should read overheating and its not.
Waterpump? or fan clutch maybe?
Old Apr 16, 2014 | 12:23 PM
Flexysammy's Avatar
Unscrew oil cap look for mil shake sounds like head gasket.
Old Apr 16, 2014 | 02:07 PM
88y0ta4x4's Avatar
coolant loss
im going to replace the thermostat first. Inspection of the oil looks normal. Another toyota guys said its a stuck open thermostat. Its a quick and easy try. If that doesnt work then i will have engine inspected for any problems.
Old Apr 16, 2014 | 02:26 PM
Just_ Rollin''s Avatar
Flush it if you haven't in a while. A very thorough flushing.
ladybugRC
458
Aug 21, 2020 10:41 AM
wberry85
May 17, 2016 05:45 PM
alexcarey
Oct 14, 2015 06:05 PM
kcaudill
Oct 10, 2015 02:39 PM
scott90
Oct 4, 2015 09:21 AM
