rust and rot frame
Old Mar 21, 2014 | 12:25 PM
aye87's Avatar
rust and rot frame
hello
1992 toyota pickup 22re 2wd Pennsylvania
i paid 1.9k for this truck but not knowing how much worse until i hit it with a hammer and found more than i expected, it is my first truck, now is toyota still replacing frame as part of recall or only to 95-00 tacomas?
i have welded patch 1/8 steel plate on some area of the frame, but it still too many rust hole
PO also welded some steel plate but they were rotted out and crack, i had to fix that by cutting PO steel plate and welding new plate in
problem area is around rear leaf spring mount bracket the most
parts replaced:
clutch/pressure plate/flywheel
4 shocks
ebay Headgasket timing chain tensioner kit
head bolts
all fluids
wiper blade
added tachometer
headlights
front brake caliper
spark plug and ignition wire
welded new glass pack muffler
spent a $grand on part
Old Mar 21, 2014 | 12:38 PM
wyoming9's Avatar
Red face
Not on something that old .
That was not a Dana Corp Frame.
That is normal for that year.
I fixed quite a few of those funny how it turns into a project.
How are the fuel and Brake lines??
Just where in Pa are you???
Old Mar 21, 2014 | 12:55 PM
aye87's Avatar
yes it will be a project
the fuel pump bracket is rusted out as with the fuel line, they will need to be replace but i dont want to spend lot of money on it
i reside at Glenside 19038
Old Mar 21, 2014 | 02:23 PM
wyoming9's Avatar
Red face
Yes indeed in the area south of 276
Good luck with your project.
I have found paint that seals the metal is a good help after the repairs.
any questions feel free to PM me
young buck
18
Aug 27, 2018 02:40 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
4x4-runner
Aug 30, 2015 08:55 AM
4x4-runner
Aug 2, 2015 09:24 AM
coryc85
Jul 6, 2015 04:07 AM
