- The little yota that could...
- Any body with pickup 2" body lift pic's???
- 1991 toyota 4wd parking lights , dash lights and brake lights not working
- Running without a belt
- 22RE or 3.0
- Which shocks?
- Center hub bolt won't loosen
- OME dakar rear leafs: anyone pulled one leaf out?
- Who knew it was a stick???
- darn tranny
- 3rd member question.
- 2nd Try Auto Transmission
- 4x4 question
- Full rebuild or just top end?
- Idle Issues - Exhaustive and Comprehensive!
- timing belt changed, anyone have this happen after?
- External head gasket leak?? 22re
- Anybody thinking about a DIY snorkle
- 22re 1st gear bogging down until WOT
- 3vze hates hills
- Coolant issues
- Got my new seat cover, and couldnt be more pleased with it!
- 2001 Tacoma Steering Wheel in 1st Gen 4Runner???
- fuel or vacuum issue?
- 22RE vacuum advance distributor
- Anyone in western Washington that knows efi well
- '86 22RE-C Engine Wiring Harness Quandry
- Questions about liftin the runner
- 22re to 22r/propane
- Wow!
- warm start knock
- passenger mirror
- V6 tranny odd question
- What happens when u used mismathched ring and pinions?
- Safari Snorkel Install 1st Gen 4Runner
- 22re help
- 89-95 LED tail lights on ebay
- 91 22re hard start when warm
- Spark Plug Wire Question
- replacement fuel tanks
- Rear 2" lift
- dashpot removal
- hunting for better mpg
- 22re new head, cam, timing kit
- 2l diesel bellhousing
- Post pics of your pre-95 STOCK Truck or Runner
- Help identifying Sensor on 3VZ
- 94 pouring out white smoke
- HELP!!! need to order replacement parts please identify
- Rough Country drop bracket lift?
- Cage for a 90 Ext. cab
- Warning lts: BRK+BATT+A/T OIL??
- Pics of your tool boxes!!
- Need help 92 4runner only starts with starting fluid
- 1990 4runner front crossmember
- Valve adjustment every 5k for how long?
- TURBO...with a carb??
- no spark
- Trail Gear Rear Bumper. Help Please.
- 22re head rear plate
- 4.10's out, 4.56's in!!
- heater/blower problem
- putting a newer cab on a 1st gen frame???
- The effects of a frozen block. Help?
- 86 4runner running rich
- Vacuum Leak?
- 305/70/16 do I need wheel spacers???
- started but died, now wont start back up
- Temp stop leak fixes for small head gasket leak?
- Help need a master window switch.
- painting the interior
- Clutch start switch/clutch cylinders
- 80 amp fusible link!
- Odd Idling issue.
- Heater hose help
- 3VZE HELP - Where do these plugs go???
- Minor rear window issue on 1989
- Size of starter bolts
- 95 4runner poss. engine conversions
- A/C o-ring kit part number
- rear differential leaking
- throttle body mod
- Help me find my oil leak
- Cant get spark
- Blower Control Removal-1994 PU
- Fuel gauge
- rear window
- Truck Bed Swap
- Heater is lukewarm, though engine warms?
- Freeze caused Milky Oil, what to look at first?
- Tire/Wheel question
- Any one recognize this bumper?
- Coolant in oil ...
- 4WD only engages when cold!!!
- b/j and torsion bars
- Idle issues after taking alot of water in
- 22RE Help!
- Block heater questions
- 95 RVZE Timing Belt won't line up
- Another heating/overheat issue
- Gearing question...
- Exhaust!!
- 86 4runner 22re headers + exhaust
- Turbo!
- Hesitation 2-3K only when it rains
- truck wont start
- Roof light cage???
- FJ rims on a 95 Runner
- 4runner dead after cold weather....help?
- Distributor pickup coil,.. HELP
- No Heat
- 94 22re rough idle bad mpg no power help
- 95 Runner Front Diff Leak, Brake Pedal Vibration Sometimes
- '93-ish donor truck (for a/c)
- 22re engine noise
- Slave cylinder in pieces
- where to find 89 FSM?
- engine clicking
- Transmission question
- Growling/roaring bearing noise, only if the right hub is locked
- 2wd to 4wd
- front brake rotor removal
- New 4Runner Owner
- HELP! Scratch in deck.
- Power Steering Problem
- Tailgate arms driving me crazy
- Odd start up and idle issues
- Broken bolt on hub
- automatic transmission issues
- Yet another *sigh* IDLE issue.
- Werid, Clutch wont release
- 95 4runner v-6 4wd 190k - fix or scrap?
- power steering fluid type
- Blown Headgasket
- Mild Lift 88 Truck
- Question about rear locker
- Front end Rattle now with some grinding noise?
- Hey efi 91 sr5 v6 ?
- Bolt-on Prerunner Bar/Bumper
- 89 leaf springs
- Crashed 93 pickup...worth the fix?
- Lights on the fritz
- *****95' 4x4, Rubbing Noise When Cold While Turning*****
- Auto t-case shifter linkage ?
- Fast ticking/whirring sound under load? 3.0 v6
- '87 22re 4runner ditributor....
- Correct choice for extended u-bolts?
- Yota on fire.
- Sudden Engine Miss at cruising speed
- Cheap Long Travel IFS
- Crown Royal shift boot?...
- 22re inconsistant idle
- Interior connector-Where does it go?
- New thermo new radiator still ovr heating. (helpppp)
- my 1990 toyota rebuild
- Major squeal on the 94 3.0 runner
- Wanted 1994 Yota std cab 2wd Diamond plate side rail caps
- Steering Box Fitment
- Toyota does not like this cold weather.
- trd 4runner locker in an sr5 4runner?
- belt diagram
- Front end rattle
- Idler arm braces
- Drivers Side Door Stuck Locked
- Dashboard Cracks (Coverking Cover?)
- Help please!! 87 4runner 22re power cutout at 1800 RPM.
- Low Budget Prerunner Build
- W56 Trans Help
- Variable speed sensor
- t100 tranny adapter
- 4x4 Lever not working?
- Difficulty shifting V6 3VZE 5spd
- Starter Solenoid Help!!
- Head Gasket Leak or Heater Core Leak?
- do i need to rebuild?
- 95 4runner v6 4x4 question
- HELP!!!!! No Power on low end and Hard starts in COLD weather.
- blower motor bad ?
- REAR Axle swap
- Timing issue
- Rough idle, hesitation, putting, Check engine light
- Papaw's 89 SR5 4x4, 3.0, trying to fix issues
- No Compression 3rd Cylinder (What next?)
- Picture of a 22R carburettor and distributor
- timing set at 15 btdc, bad?
- Noise from front passenger tire when turning left?
- gonna get cold here tonite
- Odd Noise When Driving on Highway
- automatic transmition condition. HELP
- KC Lights?
- ADD to Manual hub conversion help!!
- rolled 94 pickup
- sr5 dash?
- Shop says no alignment needed. Is it more serious?
- 22re badge for my grill
- How to determine if 2nd gen 4Runner has keyless entry
- Installing new mirror on pass side door
- 3VZ mileage
- 94 22re idles low untill I rev it once, then runs perfect. Please help
- Anyone knocking from advancing timing?
- defroster
- Reverse light question/repair.
- New Clutch for 89 22 RE 4 Runner
- crossover eliminator for the DIY
- 87 runner rides rough
- VAFM rebuild for '93 4runner
- heater blues
- 95 3vze Timing Belt alignment
- Lovin my 92 - Running after Swimming;-)
- Oil pressure needle stopped working.
- Cooling system flush
- How To- EFI early 22r
- strange engine noise
- 4 runner seat help plz!
- Stock cams with a bored over 3vz?
- Another odd idle problem
- thinking about replacing my body mounts
- help! 87 runner engine performance issue. huge miss
- 2wd grill on 4wd pickup?
- Code 41 help
- Timing!?!?!
- Help! 13mpg after Supra VAFM Swap!
- EGR and HG blowing?
- Slave cylinder looks like a pain in the....
- Not your average rear window thread
- Cutting Noisy Speedo Cable
- Trouble getting into gears: Part 2
- unusual overheating problem
- Shock questions...
- 22re exhaust manifold leak
- Aftermarket Valves?
- started building a custom grill yesterday...
- Coolant Leak
- parking brake
- JunkYard Gas Tank cleanout
- ome coils
- Figured out my timing problem
- 90 4runner bad idle after valve cover gasket replaced
- Lifting Options on 87 4runner (IFS and 4" lift kit already installed)
- Quick question about seafoam
- Strange Idle Issue
- Hilux Surf Exhaust
- Most comfortable seats in Standard Cab?
- 1988 4runner--Where are the heater relays located?
- #4 resleeve and weatherstripping
- I need a photo of a gauge connector
- Sudden loss, and return of power?
- 88 4runner
- interior sun roof cover ?.
- need a picture of auto shifter
