22re to 22r/propane
Old Dec 17, 2009 | 05:49 AM
Thecarter999's Avatar
22re to 22r/propane
I was having all sorts of problems with my wiering on my 22re so I decided to go propane. My truck is just going to be on the trail. What I have read and searched is that 85-95 the 22r and 22re are the same except for the intake. Is this correct? Will I be able to bolt on a intake from a 85-95 22r and bolt it to my 22re to run my propane. Any info advice will help thanks.
Old Dec 17, 2009 | 06:01 AM
ozziesironmanoffroad's Avatar
ur gonna find that even though the intakes bolt up with one another, the wiring harness is totally different. i pulled my cab out of a junkyard off a 1987 single cab with a 22r, (i have a 22re) and had to rip the harness out and put mine in. only plugs that r the same are the headlight plugs. have fun.
Old Dec 17, 2009 | 06:51 AM
Yea I know that, I've already pulled out all wiering in the truck. I'm gonna be running a new harness just for the esentials. This is just a trail rig. I just need to know what years a 22r intake will bolt up to a 22re head
Old Dec 17, 2009 | 01:28 PM
Called LC Enginering and talked with the tech guy. He said that there is no change in the 22r to 22re. A 22r intake will bolt up to a 22re head I will just have to put a block off plate on the head between #2-#3 cylinder. Wich LC Enginering sells the block off kit.
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
