2wd to 4wd
Old Dec 11, 2009 | 05:45 PM
CJCRunner's Avatar
2wd to 4wd
does anybody know if it is possible to make a 1986 toyota pickup with a flatbed (gardener style) into a 4wd solid axle truck with a flat bed? and if so how hard would that be?
Old Dec 11, 2009 | 05:49 PM
yoterr's Avatar
be allmost the same as an IFS swap, just you have to find a tranny and xfer case to put behind ur motor, and ur gonna need the front AND rear end.....the 2wd rear is a 7.5 and the 4wd is a 8" also the 2wd's have a lower gear ratio...so ude just be better off buying the 4wd axle's in a pair that way you allready have the right gearing...so some welding fabrication...and a crossover steering kit..399 at wabfab, addictedoffroad, or trailgear...they also sell the IFS eliminator kit for 1500 ish with a front end rebuild kit.....
Old Dec 11, 2009 | 06:09 PM
whokrz's Avatar
Anything is possible if you throw enough time/money at it.
My brother started with a 2wd for his 1uz/1tons build.
Old Dec 11, 2009 | 07:44 PM
abecedarian's Avatar
totally possible...
... BUT ...
the 2wd and 4wd chassis are somewhat different.
You already mentioned SAS, and that would be the way to go, even though there will be a lot of fabricating.
The 2wd trucks put the rear axle on top of the leaf springs so that needs changed with new perches mounted on the top of the rear axle housing and appropriate modifications with that, which will probably include lengthening the drive shaft.
Stop, think, plan. Draw pictures on paper, befores and afters.
I8URSVT
Apr 17, 2016 03:38 AM
urabus
Nov 10, 2015 07:38 PM
Daenerysdad
Oct 1, 2015 07:33 PM
83
18
Sep 21, 2015 06:15 PM
May-39
Sep 6, 2015 01:05 PM
