Major squeal on the 94 3.0 runner
Old Dec 10, 2009 | 01:17 PM
tktmsa's Avatar
So my son calls me to report a major squeal on the 94 3.0 runner and then dash lights come on, so he crept home with no power steering and no alt belt on. So we got them all replaced, I still have a major squeal happening, fan is not spinning, getting some burn on the belts.
What am I looking at here guys?
Any help is appriciated
tk
Old Dec 10, 2009 | 01:35 PM
clydehatchet's Avatar
fan pulley or clutch is locked up
Old Dec 10, 2009 | 01:40 PM
or maybe another pulley is locked up, fan doesn't always run.
Old Dec 10, 2009 | 01:46 PM
tktmsa's Avatar
and unlocking the fan pulley/clutch is done ...how?
Old Dec 10, 2009 | 01:53 PM
usually if its locked up the bearings have gone bad and shredded inside the assembly rendering the pulley unmovable. take the belts back off and go through each pulley checking to see if they move. you can obviously skip the crank pulley. if a pulley is locked, you will have to replace the part on which the pulley exists. i.e p.s. pulley is locked buy a new p.s. pump etc.
Old Dec 10, 2009 | 02:58 PM
tktmsa's Avatar
sounds good, a big thanks Clyde, I confirmed the fan clutch pulley is not moving, and I cant budge it all other pulleys are moving fine, or were when we put on the new belts.
Anyone got a part # or good source/brand/model ?
Old Dec 10, 2009 | 04:16 PM
http://www.oreillyauto.com/site/c/se...994&vi=1272484
https://www.1sttoyotaparts.com/partscat.html
Old Dec 10, 2009 | 04:39 PM
tktmsa's Avatar
These two parts have me a little confused. Am I going to need the Fan Pulley Bracket as well as the Fan Clutch? As I tear into this, will I be able to determine which one is the seized one?
Old Dec 10, 2009 | 05:10 PM
should just be the fan clutch.
Old Dec 10, 2009 | 06:42 PM
tktmsa's Avatar
I can spin the fan blade by hand, does that mean anything? Just the pulley is seized.
Old Dec 10, 2009 | 07:01 PM
yeah. here is what i would do. buy another fan clutch from parts house, go to dealer and get the pulley. i dont think you can get them from parts house. you are getting the clutch because its preventative maintenance and since you already have it off, might as well. while you are picking up your clutch, see if you can get the fan pulley from the parts house.
Old Dec 10, 2009 | 07:26 PM
Dennis140's Avatar
fan clutch mounting bracket just replaced mine dealers wants alot find aftermarket part trust me
Old Dec 11, 2009 | 01:19 PM
tktmsa's Avatar
Pretty sure it is the fan clutch mounting thing. I got the fan clutch off and pulley wheels off, the piece coming off the mount was difficult to move/spin and kind off grinds as it turns. Sound like it needs replacing ?
Old Dec 11, 2009 | 01:27 PM
yeah.
Old Dec 11, 2009 | 06:26 PM
Dennis140's Avatar
if your on the eastcoast give these guys a call
Mobile Import Salvage
7471 Theodore Dawes Rd
Theodore, AL 36582 Map
(251) 653-4050
if they don't have it refurbished the will order you a new one
pay by credit card they order and ship to you
Old Dec 11, 2009 | 07:55 PM
tktmsa's Avatar
I'm in the Rockies, needless to say I'm a chilled working on this fix. Does this bracket come off pretty easy? Got dark so I just hosed-down bolts that I could see with PB blaster to sit overnite.
Thanks guys, one more piece to do and I'm good.
Old Dec 12, 2009 | 09:04 AM
Dennis140's Avatar
its fairly easy main thing to watch for is your timing belt tensioner it removes with to bolts facing your power steering pump and you will need to key it off to be installed. its kinda easy to do just a major headache to get to and get off other than that your good
Old Dec 12, 2009 | 09:12 AM
tktmsa's Avatar
Ummm what do you mean key it off- on the tensioner?
Old Dec 13, 2009 | 09:40 AM
Dennis140's Avatar
yea its a pin cylinder a small allen wrench will fit through the casing and through the pin of the tensioner to compress it us a c clamp and slowly compress a few turns at a time going to fast can damage the cylinder once compressed align the holes and put the allen wrench through it to hold it in place until ready to be installed
Old Dec 13, 2009 | 02:07 PM
tktmsa's Avatar
OK, so I take it the allen wrench will come out without too much yanking involved?
does the tensioner pin move back-out quickly or gradually?
uncharted territory for me - thank you for the help.
