engine clicking
Old Dec 11, 2009 | 10:51 PM
europl's Avatar
engine clicking
hi i own 87 4runner 22re with 290km. my engine my clicking sound over 2500 rpm. cant figure out what it
Old Dec 11, 2009 | 11:01 PM
MuddfreaksOffroad's Avatar
is it a clicking or a slight knock? it could be your valves hitting. need more info to help you. lol could be a bunch of other things too, id check your oil, and if it needs it change the oil then go from there.
Old Dec 12, 2009 | 06:18 AM
iamsuperbleeder's Avatar
is that a complete sentence?
yeah could just need a valve adjustment
the injectors are also notorious for being loud
at worst, it could be a rod knock or piston slap
Old Dec 12, 2009 | 07:45 AM
europl's Avatar
hi when the engine is idling it works perfect but when the rpm goes over 2500 it stars making a clicking sound. I try to change my oil every 5000 km. i run it on 10W 30 synthetic oil. thanks
Old Dec 14, 2009 | 12:52 PM
yeah it was a complete sentence to me hahahaha who cares??? anyways well if it does it at that rpm and not at idle id say look into the valves or like super bleeder said the injectors might be the prob. Personally i dont work on the efi yotas that much so im not super sure on that but lookinto those possiblities. could also be a spark plug wire jumping. i had a wire that i didnt know was bad and it actually came apart a lil at the end where the spark plug is and it was jumping across to the spark plug cylinder wall and altho it was stilll firing it would cause my car to make a faint clicking sound and it caused my car to start back firing at a certain rpm/ speed SO idk could check that, but my car is a 96 dodge neon. lol
Old Dec 14, 2009 | 02:06 PM
aw, edit your post and make me look like a fool why don't you
Old Dec 14, 2009 | 02:10 PM
91Toyota's Avatar
When these engines first came off the assembly line they fired them up and made sure they were ticking. If it didn't tick, they would throw it out, and if it did, it would be good for life
Sandman
Jul 14, 2015 12:36 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
cars-guy
Jul 11, 2015 07:51 PM
colinmil
Jul 6, 2015 04:03 PM
