rear differential leaking
Old Dec 13, 2009 | 07:06 PM
OltorfTD's Avatar
It looks like there's a leak between the third member housing and axle housing on my 94 pickup. Is there a gasket between those two that would go out or anything? Any other possible causes?
Old Dec 13, 2009 | 07:58 PM
myyota's Avatar
Theres no gasket, there usually sealed with a silicone sealer like ultra black or something like that, and the only way to fix it is to pull the axles and remove the third member and reseal it. You might also want to check the axle vent to make sure its not plugged.
Old Dec 13, 2009 | 08:10 PM
OltorfTD's Avatar
where is the axle vent, and how can you tell if it's plugged?
Old Dec 13, 2009 | 08:37 PM
myyota's Avatar
It a little cap looking thing thats screwed in the top of the third member housing. unscrew it from the diff housing and make sure its not plugged.
Old Dec 13, 2009 | 08:45 PM
OltorfTD's Avatar
thanks, i'll check as soon as i get some day light.
Old Dec 13, 2009 | 09:12 PM
SwampThing's Avatar
It's located right here (where the tube is attached):
Old Dec 14, 2009 | 02:24 PM
iamsuperbleeder's Avatar
no gasket?
ummm, I put on between my 3rd and the housing with I did mine a while back...
sure I used RTV as well, but I did put a new gasket there; just to help keep the RTV in place a little
and there WAS a gasket already on it when I pulled the third, so they DO come with gaskets on them...
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Avenged
Jul 9, 2015 07:55 AM
AaronM
Jul 8, 2015 07:15 PM
