rolled 94 pickup
Old Dec 8, 2009 | 05:11 PM
TomkiRider's Avatar
rolled 94 pickup
hey guys i was wonderin if anybody might be able to help me out. i rolled my 1994 v6 5 speed xcab pick up on its lid a couple weeks back. we got it right side up within 10 minutes. have the cab beat back out for the most part. but its havin trouble running.
drained all the oil, put new oil in it. pulled the plugs and made sure they werent fouled got what i BELIEVE to be most of the oil out of the cylinders. through all the intake tubes in the parts cleaner cuz they had oil in them. it cranks over but will not start. spray eather in the intake while cranking and itll run on that for a split second but try throttle and nothing.
any suggestions? is there a sensor somewhere like on a ford that trips when the trucks flipped over?
Old Dec 8, 2009 | 05:19 PM
DupermanDave's Avatar
Is it possible the timing chain jumped a few teeth? I've heard of this happening a few times on 4runners.
Old Dec 8, 2009 | 05:27 PM
TomkiRider's Avatar
wouldlnt it make an off noise while cranking over?
Old Dec 8, 2009 | 05:36 PM
TomkiRider's Avatar
its a belt anyway...
Old Dec 8, 2009 | 06:18 PM
1989toy4wd's Avatar
Sounds like a fuel issue since it will run on ether, check the fuel pressure if you have the means to do so. If not have someone turn the truck to on while you are standing near the fuel tank and listen for the pump to turn on, I dont know if 94s have the diagnostic port, but you can always jump the B+ and Fp terminals and listen for the pump then also.
Old Dec 10, 2009 | 05:57 PM
sotb3's Avatar
there's a fuel shutoff thingy under the passenger side outer kick panel if i remember right--same one it says to use in order to relieve pressure when changinging fuel filter--having a hard time right now remembering if that's right but i'm sure the toy tech GODS will make it all better if i'm wrong--good luck
jasonty
41
Dec 23, 2018 01:00 PM
shisha1999
Mar 16, 2016 12:25 PM
Sep 4, 2015 09:27 AM
DrZero
18
Jul 24, 2015 11:31 PM
