W56 Trans Help
Old Dec 9, 2009 | 06:33 PM
Lowboy's Avatar
W56 Trans Help
I have a w56 and today the shifter got very very sloppy, i can move in 360 degrees basically, it svery hard to "find" gears, but if I have a little luck and dont press too hard into each gear it will go.
I took the shifter and housing off and it seems like the detent spring things, Im not sure what they are actually called, are worn badly and sticking so im hoping that by replacing them my tranny will start working correctly again, only problem is, is that I cant find them anywhere, anyone know who sells them?
Thanks
Old Dec 9, 2009 | 06:59 PM
rustypigeon's Avatar
Check your shifter bushing. When they go, the stick moves all over the place making it hard to find the gears.
Old Dec 9, 2009 | 07:17 PM
Lowboy's Avatar
I did theyre still new and good, theyre the marlin crawler upgrade bushing, replacing the detent things is is the only thing i can think to do before i conclude that its a broken shifter rail, and pull the tranny
Old Dec 9, 2009 | 10:15 PM
wyoming9's Avatar
Red face
Does it jump out of gear at all once you do mange to get it in gear??
Does it grind at all ??
Old Dec 10, 2009 | 07:07 AM
Lowboy's Avatar
It doesnt grind at all, and it doesnt jump out of gear, if I manage to get it in gear a can move the shifter all around to pretty much all the other gears and it will stay in gear, it comes out if I go near neutral
Old Dec 10, 2009 | 07:42 AM
shaeff's Avatar
Marlin Crawler might sell heavier duty detent springs. I don't remember. Failing that, you can still get them from the Toyota Dealership.
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
beebeeri000
Oct 2, 2015 10:42 PM
tshort48
Sep 27, 2015 01:04 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
