rear window
Old Dec 13, 2009 | 03:40 PM
s.resko's Avatar
rear window
how do i fix my rear window in a 1991 4runner it is extremely tempermental and i am afraid to lower it just incase it does not go up when im done. i have searched to no avail
Old Dec 13, 2009 | 03:55 PM
eli-sky's Avatar
look harder. i highly doubt anyone other then i will answer
Old Dec 13, 2009 | 06:19 PM
limon32's Avatar
I'll answer for kicks...
I don't even have a 4runner and I can tell you that there is a long list of reasons for it to be temperamental: bad wiring, bad connection to motor, bad regulator, bad gears, window out of track, bad switch...
Get the idea? You really need to provide a bit more info on what its doing and not doing if you want anyone to help you.
Old Dec 13, 2009 | 09:39 PM
RobD's Avatar
Give this a read:
http://forum.ih8mud.com/79-95-toyota...ay-repair.html
Old Dec 13, 2009 | 10:09 PM
myyota's Avatar
I ordered new heavier duty relays for the relay control, the stock relays are rated at 7 amps and the new relays are rated at 10 amps, they should hold up a little better under load.
Old Dec 13, 2009 | 10:14 PM
Dbl. E's Avatar
4crawler.com has a bunch of info about fixing rear window issues.
Old Dec 14, 2009 | 04:04 PM
s.resko's Avatar
word well the switch just clicks and the window may go down after about 15 clicks i may just get a new complete working tailgate assembly but i have some cool stickers i would have to part with :/
Jun 1, 2021 01:51 PM
RustBucket
Jul 24, 2015 04:46 AM
sabine
Jul 18, 2015 03:59 PM
icentropy
Jul 14, 2015 10:23 AM
coryc85
Jul 6, 2015 04:07 AM
