belt diagram
Old Dec 10, 2009 | 07:38 AM
tktmsa's Avatar
belt diagram
Hit 8 below zero (F) last night, one of my belts snapped as I was almost home, my FSM download is a mess after some computer trouble can any one post a link or diagram on what goes where (3.slow)- Thanks! burrrrrrrrrr
Old Dec 10, 2009 | 08:41 AM
Tubbyfatty's Avatar
The power steering belt is the first one you can get at when everything is on. It goes from the pump to the fan bracket pulley then to the crank.
Next is the AC belt, if yo uhave it. It just goes to the crank from the AC.
Then the belt furthest back is the alt, i think it goes to the crank and back.
P/S - fan pulley - crank
AC - small AC adjuster pulley - crank
Alt - crank
Old Dec 10, 2009 | 09:01 AM
tktmsa's Avatar
Thanks Tub,
Can you point me to the tensioners for each belt ?
Do I have to remove the fan to get the belts on?
Any visuals around? The FSM and my Haynes manual are wonderfully vague.
Old Dec 10, 2009 | 09:05 AM
Ardent's Avatar
the PS pump is the tensioner for its belt.
The Alt is the tensioner for its belt.
The AC has a tensioner pulley. Its the lowest pulley on the front of the engine and has an adjustment bolt on it. You have to loosen the bolt that goes through the pulley then you can adjust it.
Old Dec 10, 2009 | 12:17 PM
tktmsa's Avatar
getting the PS pulley to move is done how ?
Old Dec 10, 2009 | 01:12 PM
tktmsa's Avatar
got them all on, I have a major squeal happening, fan is not spinning, see new thread = Major Squeal.
zytra
Jan 24, 2019 03:16 PM
primordialbeast117
Dec 19, 2015 12:23 PM
moparbay
Oct 6, 2015 09:24 AM
EVars
Sep 29, 2015 02:06 PM
gentry
Sep 28, 2015 06:16 AM
