darn tranny
Old Dec 18, 2009 | 12:50 PM
toomster's Avatar
darn tranny
Hello all, 1990 toyota 4runner with 22re and 5spd manual. Wife just called said she couldnt shift the truck into any gear. She pulled off the road, turned off the truck, and with the engine off she could shift through the gears. Started back up, got moving in first, went to shift into second, and could not get into any gear again. Pulled off the road and tried one more time, and it was good to go. My fear is the shift forks are getting screwed up. She said the clutch felt fine, and the gears wouldnt grind while she was trying to put it into gear. Anyone have any thoughts? Do I need to start looking for a new tranny?
Old Dec 18, 2009 | 10:02 PM
Matt90V6SR5's Avatar
Glad your wifes ok,good luck not spending lots of money.Hope its something simple.
Old Dec 19, 2009 | 12:09 AM
DeathCougar's Avatar
I highly doubt its the "shift forks"
Sounds like the clutch simply isn't disengaging, due to a failed master cylinder. My master felt just fine when it failed, and I couldn't get it into gear unless the engine was off. Start by making sure the master isn't leaking into the pass compartment, and that the slave is working as well. Have your wife push on the clutch, and watch the slave rod to be sure its pushing on the shift fork. It takes about 1/2"-3/4" movement to disengage the clutch.
If that is working, them you can dig deeper into the tranny.
Old Dec 19, 2009 | 05:44 AM
rustypigeon's Avatar
Check that the clutch pedal bracket isn't broken. When the bracket breaks, you can't shift into gears when the truck is moving, and it grinds when trying to go into reverse.
Old Dec 19, 2009 | 10:34 AM
toomster's Avatar
Hello all spent a couple hours last night driving the thing trying to get it to do the same thing again, to no avail. Thanks for the thought on the master cylender I'll check that, and the slave while Im at it.
Thanks
Old Dec 19, 2009 | 10:46 AM
DupermanDave's Avatar
Thanks
So the problem went away when you went to drive it? Hmm. The truck doesn't like her. She's doing something wrong to it.
Old Feb 21, 2011 | 07:16 AM
Smeddy2's Avatar
Did you ever figure anything out on this issue? My truck did the same EXACT thing yesterday. I have a brand new slave cylinder and my fluid is all filled up. Looks like the PO put on a brand new master as well.
Old Feb 21, 2011 | 07:41 AM
blake.nemitz's Avatar
brackets are notorious for breaking or getting weak and flexing, think about it a couple hundred thousand miles and millions of pedal cycles it will wear out
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
