22r / 22re build up... possible hybrid?
Old 02-14-2011, 09:30 PM
americanmcss's Avatar
Hey everyone, its been a while since i have been on here. I managed to find myself a pair of 22r's for sale locally for $100, and jumped on the opportunity to grab them. One is complete with carb, intake and exhaust manifolds, distributor and even part of the harness, the other is basically a long block with some possible head damage. What I need to know is between the 22r and 22re, which major engine components are compatable? I am mostly concerned with the head. (I have a 22re in my truck and I know that there are some differences between it and the two heads i just bought) Are the heads compatable? The reason i am going this route is because I cannot afford to have the engine in my truck down for an extended period of time and would love to be able to build slowly and then swap quickly in a weekend when the engine was finished.
Any thoughts or ideas would be greatly appreciated. Also, I am considering a making a 22retc clone/redheaded step child motor, so anyone who has a source on what is needed to do the conversion, that would be appreciated as well thanks...
I'll try to get some tear down pictures up as soon as I start tearing into the blocks...everyone likes pictures.
(I'm not really concerned with making a lot of power with this engine, but I would like to do it as I have never done much with turbo charging, so for that reason I don't need to hear about swapping in a 4.3L or a small block)
Old 02-14-2011, 10:04 PM
weaselman's Avatar
the heads are basically the same, depending on years.
i have used a 84 CARB head on my 86 EFI block
i have used a 85 CARB head on my 86 EFI block.
i have used 85 EFI head on my 86 EFI Block
the turbo conversion will prolly take you a while unless you source all the parts (quite a few and somewhat hard to find/expensive) before you do a tear down.
Old 02-15-2011, 04:52 AM
spokane.yota.man's Avatar
All 85 to 95 22r and 22re were the same, block and head. The turbos were different, less compression and different pistons for one. The 81 to 84 22r were also a little different. I believe the intake bolt pattern was slightly different for one thing. I don't think It's as easy as bolting up a turbo to the 22r/re. Some internal stuff is different. You should try though, I would love to do this same thing one day. Turbos are cool! Good luck.
Old 02-15-2011, 04:56 AM
xxxtreme22r's Avatar
I remember someone on here saying something about compression ratios being different between 22r's and 22re's. Which ended up with different specs from different sites. And I am not talking just 81-82 82-83 84-85 86-95 differences either.
And an 84 head on an 86 block will result in hello low compression.
and an 86 head will not fit on an 84 block. Not with the pistons in the block anyway.
Old 02-15-2011, 09:48 AM
Yeah I suppose I need to run the engine serial numbers to find out a little more about them before I start making plans. If anyone knows where i might be able to find a good comprehensive engine parts manual that contains 22r, 22re, and 22retc parts.
When it comes to the turbo issue, I was thinking about making it more of an aftermarket setup, rather than a true 22retc, because the parts are probably more readily available. I would say like a squires turbo systems type thing.
Old 02-15-2011, 09:55 AM
strykersd's Avatar
I'm curious if that's even possible. Will the timing chain compensate for the 3mm taller head?
Old 02-15-2011, 09:57 AM
http://www.lcengineering.com/TechNotes/?techid=49
Cylinder Head Identification
1975 - 1980 20R Cylinder Head
Round Intake Port
Round Exhaust Port
80/81 C.C. Chamber
Intake Valve Diameter 43mm
Exhaust Valve Diameter 35mm
1981 - 1984 22R Cylinder Head
Square Intake Port
Round Exhaust Port
82/83 C.C. Chamber
Intake Valve Diameter 44.5mm
Exhaust Valve Diameter 36.5mm
1985 - 1995 22R-22RE Cylinder Head
Square Intake Port
Pear Shape Exhaust Port
52/54 C.C. Combustion Chamber
82/83 C.C. Chamber (Turbo) Intake Valve Diameter 44.5mm
Engine Block Identification
1975 - 1980 20R Block
Deck Height 11.280\"
Stock Bore 88.5mm - 3.484\"
Maximum Over Bore 90.0mm - 3.544\"
1981 - 1984 22R Block
Stock Bore 92.0mm - 3.622\"
Maximum Over Bore (Cast Piston) 93.0mm - 3.662\" (+.040\" Over)
Big Bore Forged Piston Kit 94.0mm - 3.701\" (+.080\" Over)
1985 - 1995 22R-22RE \"Laser Block\"
Deck Height 11.090\"
Maximum Over Bore (Cast Piston) 93.0mm - 3.6662\" (+.040\")
All Toyota 20R - 22R - 22RE engines use the same crankshaft and connecting rods. To accommodate the different deck heights, Toyota changed the compression height (piston pin location).
Crankshaft (Forged)
Stroke All 20R - 22R - 22RE 89mm - 3.5039\"
Rod Journal 2.0861 to 2.086\" (standard)
Main Journal 2.3614 to 2.13622\" (standard)
Connecting Rod (Forged)
Center to center length 5.830\"
Note: Early 81-84 22R - 22RE and Late 85 -95 22R / 22RE Engine Blocks
Cylinder Heads DO NOT INTERCHANGE without considerable modifications
http://www.lcengineering.com/TechNotes/?techid=8
1975 1982 20R Cylinder Head
Round Intake Port / Round Exhaust Port
80 / 81cc Chamber
In. Valve Dia. 43mm / Ex. Valve Dia. 35mm
1981 / 84 22R / RE Cylinder Head
Square Intake Port / Round Exhaust Port
82 /83 cc Chamber
In. Valve Dia. 44.5mm / Ex. Valve Dia. 36.5mm
1985 / 95 22R / RE Cylinder Head
Square Intake Port / Pear Shaped Exhaust Port
58 cc Chamber or 22RET (Turbo)
In. Valve Dia. 44.5mm / Ex Valve Dia. 36.5mm
cyl head height is the same it's the block height that is different. As well as the chamber shape.
Old 02-15-2011, 08:34 PM
Wow thanks for the info xtreme... So as long as the head is a post 1985 22r, I should be in good shape correct?
Old 02-17-2011, 10:00 AM
Got some pictures for everyone to look at if interested. It looks like they are both pre-85 blocks, and unfortunately i can see my dreams of this projects slipping away...
This is my platform...
Old 02-17-2011, 10:12 AM
yup, those are pre-85 engines, great platform for a 22r/20r hybrid though.
Old 02-17-2011, 10:18 AM
So is there anyway to turn that engine into a 22re?
Old 02-17-2011, 10:30 AM
you'd have to find a pre 85 22re intake manifold at the very least, not sure if all of the injectors for a post 85 will work in it though, as well as weather or not the programming of the post 85 ecu will be kind to those engines or not. Then there might be an issue with the exhaust manifold bolting up, but I think they will even though the port shapes are different. Might have to delete the air injection stuff though if they do.
I know all of the differences, but not sure on some things that will and wont work as far as crossing them.
Old 02-17-2011, 11:00 AM
Well thats a big giant kick in the nads. The only thing i found that might be any good is the fact that the post 85 22rte's had the larger 82cc combustion chamber. So everything else aside, why wont the 22re intake bolt up to the early head? All the heads that they sell online now are retro-compatable. I have a good exhaust manifold i can use on it since the bolt pattern is different.
Old 02-17-2011, 12:38 PM
scratch what I said about the intake, the intake ports are the same, it's the exhaust ports only that are different.
Old 02-17-2011, 03:45 PM
87trustyrusty's Avatar
the 22re intake will bolt to the older 22r head, put 82 motor in a 86 and used 86 intake works great
Old 02-17-2011, 06:51 PM
Excellent... Well with the bigger combustion chambers (82 in old head vs. 58 in new) I wonder what kind of differences you would see in hp/torque/fuel efficiency?
Old 02-21-2011, 08:11 AM
Started tearing into the motor this weekend, and everything looked great until found some tan pudding in the water pump housing. Is this an indication of oil? I found no trace of water in the oil though so it was only a one way leak. I'll get some picures of my progress up later today.
06-01-2021 01:51 PM
cars-guy
08-16-2020 06:59 AM
young buck
18
08-27-2018 02:40 PM
dumpster84
04-30-2016 06:03 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: 22r / 22re build up... possible hybrid?
