22re help
Old Dec 16, 2009 | 10:31 AM
hgpilot's Avatar
22re help
93 truck, 22re.....in neutral at idle it runs smooth, advance the engine to about 1500 to 2500 rpm and it starts to pop, misfire, cough.....any help out there. just put a new engine in and it was having the same problem before the swap.
Old Dec 16, 2009 | 10:39 AM
Windsor's Avatar
fuel filter plugged?
Old Dec 16, 2009 | 07:27 PM
hgpilot's Avatar
I'll change it, anything else it might be?
Old Dec 16, 2009 | 07:31 PM
abecedarian's Avatar
check for vacuum leaks
Old Dec 16, 2009 | 07:35 PM
Windsor's Avatar
You're saying it has happened across two engines, so fuel delivery seems to be the only common component.
Generally speaking, ok idle and sputtering/coughing at a non-idle speed is either ignition problems (timing, weak coil, funky plugs, seriously funky wires) or fuel delivery (weak pump, clogged filter, bad injectors).
Toyota pickups/4runners aren't notorious for fuel pump failures, so I didn't consider that a viable problem.
Old Dec 17, 2009 | 06:43 PM
rangerruck's Avatar
how about an egr valve? that or vaccuum prob , I would think...
Old Dec 17, 2009 | 07:16 PM
Windsor's Avatar
vacuum/air leaks usually fiddle with the idle and less problems as you go up in RPMs.
Another thing I just thought of.. O2 sensor will do this, too. I would think you'd get a Check Engine light, but could be a few reasons why it didn't come on.
Old Dec 17, 2009 | 07:22 PM
Kiroshu's Avatar
Tune-up? Vac leaks? EGR(unplug vac line to it and see if it stops). Check fuel pressure.
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
