Noise from front passenger tire when turning left?
Old Dec 8, 2009 | 07:41 PM
deadduckky's Avatar
Question Noise from front passenger tire when turning left?
I've been hearing a grinding/ rubing noise only when I turn left, it only last for a second though. I've done some searches and it sounds like it has to be the CV shaft. Is there anything else I need to look for?? Possible bearing??
Old Dec 8, 2009 | 07:52 PM
iamsuperbleeder's Avatar
at full-lock left?
click search, and type in "steering stops"
Old Dec 8, 2009 | 08:08 PM
deadduckky's Avatar
No its not allways at a full turn but I saw that steering stop and dont think its that.
Old Dec 8, 2009 | 08:41 PM
ajury's Avatar
rub
I had a problem with my 89 toyota pickup.
Noise was caused by the lower skirt under the bumper bending back and rubbing the tire. Yours might be more serious but check this out before you spend a bunch of time on it. I felt silly when someone (standing outside the pickup) pointed it out.
good luck.
Art
Old Dec 8, 2009 | 11:08 PM
peow130's Avatar
CV's will click when they're broken...
Old Dec 9, 2009 | 06:22 AM
ET's Avatar
ET
yeah, check your splash guards. mines torn a bit and it rubs on the tire when turning.
Old Dec 9, 2009 | 03:48 PM
deadduckky's Avatar
I crawled under and the "splash guard" does not seem to come close to my tire. I'm gonna just drive it till I can narrow it down a bit.
Thanks everyone for the input
Old Dec 9, 2009 | 04:06 PM
91_TOYOTA_4x4's Avatar
ok not saying this is it but my right front knuckle and cv shaft was worn out and it got so bad that it would vibrate and whine when i drove but it would go away some times. it always happened when i took a right corner. anyways took it all apart and the cv shaft inside the knuckle could mover back and forth like crazy. so i t wore out the brass sleave in the knuckle and the shaft was toast. new knuckle and cv . anyways i would check that out. just pop you tire off and the hub and see if the shaft has any play.
Bamripzit
Jul 19, 2015 01:17 PM
Bamripzit
Jul 13, 2015 07:21 PM
Vargntucson
Jul 4, 2015 12:15 PM
Mr.Black
Jun 21, 2015 10:17 AM
