Running without a belt
Old Dec 18, 2009 | 04:05 PM
Paulsky's Avatar
1991 22RE. My air conditioning belt broke off. It runs straight off the main shaft without any other accessories on that belt. I shouldn't run into any problems running without it, right? I just won't have air conditioning, which given current air temperature is not an issue. Am I thinking straight? If anyone is aware of any possible damage I could inflict by doing this, let me know.
Old Dec 18, 2009 | 04:25 PM
whokrz's Avatar
Should be fine just make sure the tensioner part can't unscrew its self and fall off while you are driving it.
Old Dec 18, 2009 | 04:51 PM
streetlancer's Avatar
You will be just fine.
I am currently in the same boat only difference is I don't have power steering either.
But that is due to a noisy idler pulley that i will soon be putting back on.
By the way does anyone know the order the pulley goes in??
I was too lazy to take pictures and forgot the order, there is 1 flat washer, 1 lock washer, a nut, and which way does the pulley go?
Old Dec 18, 2009 | 04:53 PM
TOYOTA 1's Avatar
watch out, your pants might fall down!
Old Dec 18, 2009 | 05:11 PM
BigBluePile's Avatar
HA! You beat me to it!!
You could say you caught me with my pants down...
Guess I should buckle down next time...
Old Dec 18, 2009 | 05:30 PM
stormin94's Avatar
I heard the defroster uses the A/C compressor to remove the moisture out of the air. I'm not sure if there's anything to that, but maybe the defroster won't work as well.
Old Dec 18, 2009 | 05:51 PM
Ha! Ha! Ha!
Doug4320
Mar 24, 2018 10:11 PM
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
dinks07
Jul 15, 2015 05:34 PM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
