- 91 Tacoma To 93 T 100 3.0 Change
- running rich
- Looking for dual side draft carbs for 77' 20r
- tranfercase question
- manual hub swap from add????
- Best place to get a good 22re, reman or new?
- 4runner exhaust is smokey?
- Difficulty of water Pump install (should i burp)
- yet another tire change question, as well as exhaust
- 1983 5spd tranny in 1993 truck?
- Update on idle, made more progress today
- Trouble Code Experts...Need Verification on Codes I'm getting from my 88 22RE
- Rough Idle 22re
- getting ready for 2jgte.
- Stock Roof Rack
- spark plugs
- Common problems 1993 4x4
- coolant temp sensor problems
- 87 pickup rough idle in the rain
- 86 22re code clearing?
- temp gauge bouncing around??
- 5.29's Does brand matter?
- Try Amsoil!
- 22r-e Surges @ 2000 Rpm's
- what to do while valve covers are off?
- exhaust gasket?
- bad smell from exhaust and power power on freeway help asap on way to cali
- Weak reverse gear on auto trans
- '89 Truck Door
- 22re timing problems....
- TPS, AFM, Timing... I'm making progress
- 4x4 newbie with a million questions :)
- Fuel Line Part Numbers
- Oil in 22RE intake manifold!?!
- need carb help 22r
- can i put fj cruiser rear coils on my 94?
- i got another runner
- new muffler
- code 71 and vacuum lines.
- 94 4Runner V6 problem/ fuel filter
- Not Too Bad....
- Gears Gears and more gears
- Failed Emissions..High NO levels
- front sway bar end link
- clear tail lights for my 94?
- Lift block deminsions?
- 22re charge light
- Need some bad bondo body work advice
- 22R will not idle
- 86 22re cold start problems.
- Somebody Buy It...
- exhaust any tips?
- 4 runner 3.0 fuel injector replacement
- 93 22re miss firing
- Looking For 1990 4runner Engine
- 4 Runner caught fire
- w56 transmission rebuild results: grabby.
- Catalytic Converter Stolen! At School!!!
- broken parts-pics
- Lunchbox reverse
- Temp control stopped working
- better ride out of the front suspension
- K&N intake really good deal
- Survival build.
- surging when brake is applied
- newbie please help
- 86 22rtec turbo . rebuliding turbo help!!
- throttle valve linkage cable
- u-bolt flip with square u-bolts?
- buying a 88 4runner
- 3.0 tranny pan gasket Help
- Semi-floating conversion
- gap guard help
- What glue to use?
- 95 3VZE Problem. Code 14
- Cheap red paint?
- will these fit my truck?
- 4 Wheel & Off Road Magazine-Reader's Ride
- $80 For Mud Flaps!!!!?!?!?!
- Softer Quieter Smoother Ride?
- Opening up the rear tailgate/window on a 95
- No oil pressure on new rebuild 22re
- Vaccumm Hoses Missing?
- 89 3.0 hard to start when cold
- Low oil pressure, hot engine I Need Help!
- Aisin Hub Problem
- removing windsheild trim
- #93rustedyota's build thread 1.0#
- is this red a toyota color?
- transmission wont go in to reverse
- Tune up
- sas poser pics.
- engine swap
- I give up...where are they?
- Starting to strip my Donor truck for my 3.0 swap.
- trouble converting from an automatic to a stick.
- Pictures of my 86. Enjoy and thanks!
- lookin for a pointer in the right place for the right parts
- Whats the deal with my lift?
- Heater issues
- 95 vs 95.5 Generations
- Machine work when putting in o/s valves
- '94 22RE downpipe replacement.
- Loss of oil pressure.
- Is it worth it? 95 4runner ?
- valve covers
- 3.0L over heating
- New Owner and Got a Leak...Help
- 2wd... Is It Worth It?
- 90 4Runner
- base timing
- flashing od light
- 90 factory alarm system 4runner HELP
- found my donor truck!
- Need Wiring Help!!! ASAP
- Can someone tell me if this is right?
- exhaust
- Newbie Problems!
- Clicking Tach/Speedo
- i think i toasted my alternator
- I messed up my 4runner! Air Flow Meter Problem
- 20r from a celica fit in a 87 2x4?
- Manual Trans Compatibility
- Soft top on craigslist
- bought a used tranny
- strange noise in the head ?
- Alright, Another Overheating Question..Kind of Long Winded
- ignition switch problem
- Newbie check out my new 4runner and give me some pointers
- Gears, Lockers, Prices...
- Engine Services in WA
- 1987 4Runner SR5 4wd won't engage
- 3.0 rebuild kit
- electronics on 3vze 89 to 90
- 4runner power window issues
- Best spark plugs?
- How can I tell if my engine is ACTUALLY overheating?
- power antenna relay
- Gas Cap Door
- Hard shifting transmission - final solution needed
- help with 87 toyota 4x4 turbo
- Looking for a Toyota genius!
- Wheel/Tire clearance?????
- lock right locker???
- 1st gen 4runners to repeat FJ-40?
- Headlight Wiring - Quick Help!
- S.O.B! Brakes R pissing me off! ...help?
- Which Cold Air Intake Should I Buy
- 31/9.50/15's? I need help finding a set.
- thinkin about a new paint job what you think?
- warm rattle rattle rattle *please help*
- 4.88 gears
- Choking and gagging issue
- Yukon install kit on an 86 different than 85?
- Stuck
- 94 yota brake Master Cylinder
- Differential breather extension
- Bucket Seat Swap in my '88 Pickup
- Missing my first truck (pics)
- Egr
- Carb Options...
- where does charcoal cannister bottom hose terminate
- Alternator??
- 4cyl diff into V6 housing
- 22RE Head & head gasket replacement tips????!!
- 94 toyota need help?
- 3.0 Fuel Filter Replacement Write-Up by Infiltrator
- 22re surging problem SOLVED!
- Catalytic Converter inlet size?
- Body Lift Question
- 22RE Anti-freeze Loss
- Omg wtf mate snow? snwshoot
- post your unique modifications!!!
- 31's Or 33's
- best cap/rotor button ?
- New 2nd Gen 4runner... any of these issues major?
- 22re idle update.
- 22re idle problem
- Need sanity check by Yota experts: R2ing leaky timing cover gasket
- Yakima rack on bald 4runner
- 91 3VZE Code 52 Help
- Hilux Surf/4Runner Performance
- Headlight Rewire for HID Conversion
- Need to clear up sone suspension questions
- 22re won't idle
- 81 4x4 motor into a 87 2x4, will it fit?
- Wheels & Offset information-Please.
- Shocks for a mild lift?
- Looking at 2nd Gen Runners
- Steering stabilizer (OME)....I got a ?
- Opinions on radiator options needed
- What is this bumper called?
- IS 35 inch tires to big for the e-z locker
- Ordered an Aussie Locker
- 22 RE rough idle
- Oil pressure?
- blown head gasket! damn...
- What is this part? 22R
- Need assistance on 88 toyota 4x4 vibration ocurring
- Another 4wd light Issue (I searched also)
- Headers And Exhaust Question
- Shocks coming up...
- 1988 22re timing problems from rebuild
- Afm Relocate...dual Battery Upgrade..snorkel Prep
- Do I need to raplace all head bolts?
- Free Power From The 3.0!!
- 4Runner 1.5 inch lift shocks ASAP
- 4runner IFS or Frame Problems?
- Suspension lift question
- 4runner w/corolla fuel filter???
- 94 4 runner 4.56 diffs in a 88 pickup?
- 87 4Runner power window conversion
- Head Gasket Change on 22RE - Advice Please - PICS
- 2nd gen HG longevity question
- 22re HG replacement, difficult?
- Power Steering Question
- found wire !!
- Master Cylinder Cap seal
- starter problems
- Exhaust oops
- How streetable are balljoint spacers?
- ARB install
- After Body Work and Diff. Breathers
- I Got One!!!!!!
- 1987 22R Cali Edition Engine Help
- Suspension lift installers in Denver, Colorado?
- WTB-2nd gen alternator (91 or 92)
- Noisy Top End 1991 Toyota 4Runner
- RPM and Fuel Gauges off!!
- Oil change 22re
- 1992 SR5 3-vze advice
- check engine light CODES ???
- spark plugs, watery gas
- Is this the right direct replacement engine for me
- LSD Questions
- 90 sr5 - 94 non sr5 compatibility
- ? For those of u who have headers on your 3.0
- '94 22re rough idle?!
- Jumping Tach
- 22re sparkplugs/wires
- Another drop in 'mileage'. This one is big.
- Why do swing out spare carriers seem so rare?- 4Runners
- Electrical Diagnostic Help
- Grounding ?
- where to buy new battery terminals?
- Paint in valve Cover??
- 86 Toy raliability?
- A stock look for a Winch Mounted Bumper!
- 86 to 91 axle compatibility
