flashing od light
Old Mar 15, 2008 | 05:47 PM
js9924's Avatar
flashing od light
I have no idea why and cant find my manual but does anyone know why my overdrive light might be flashing?
P.S. it doesnt do it all the time.
Old Mar 15, 2008 | 05:50 PM
DeathCougar's Avatar
OD light flashing means you have an overdrive issue. I believe its possible to pull a code, but Im not 100% sure.
Old Mar 15, 2008 | 06:51 PM
4runnerx3's Avatar
The OD light flashes when the transmission control unit has a stored code. These codes are only for electrical problems. You can have a mechanical failure by a solenoid and there will be no code, but if something electrically happens to the solenoid, you have a code. These are the codes for an '86. To pull the codes on a 86, there is a small square plug behind the afm that you ground. I don't know if the codes are the same for a 94 or how to pull them.
Old Mar 16, 2008 | 06:28 AM
thook's Avatar
To pull the codes on the transmission you use the same method as you would to pull the engine codes. Should be, anyway, if your truck has the little grey style diagnostic port. For that year, I'm assuming you would. TE1 and E1 terminals with the O/D switch on OFF position.
Old Mar 16, 2008 | 08:37 PM
js9924's Avatar
thanks a lot guys I tried to pull the codes by jumping the diagnostic port and got nothing. I just had the tranny serviced would this have anything to do with it? pulled the efi fuse and reset but it came back.
Also I am having trouble getting moving when the truck is cold the motor is fine but i have to rev like crazy before it starts to move forward or backward. once its hot its fine is this the flex plate issue ive heard of?
Old Mar 16, 2008 | 08:43 PM
thook's Avatar
You got nothing? Was O/D light lit up (OFF position) when you jumped the terminals? And, what do you mean by nothing?
Old Mar 16, 2008 | 10:43 PM
SpecialScottie's Avatar
Mine was blinking when my transmission oil low
Old Mar 17, 2008 | 05:49 AM
js9924's Avatar
it means there was no code, but I just did it again and realized I didnt have the button set in the right position now im getting code 61 62 &64 looks like ill be replacing some solenoids thanks fellas as always someone comes through.
Old Mar 17, 2008 | 06:00 AM
js9924's Avatar
ok so out of curiosity I crawled under the truck and started following the wires and sure enough the speed sensor is unplugged. no more codes! I guess #2 speed sensor and the 1&3 solenoids are on the same circuit somehow? oh well lets see if this stops the slipping as well. I think it should thanks again all
ashersullivan88yota
Jan 18, 2022 05:37 PM
Shoua
13
May 22, 2016 05:19 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
