check engine light CODES ???
Old Mar 11, 2008 | 04:47 AM
Shock5's Avatar
Can I pull codes and read them without a scanner? If so how is it performed?
Thanks
Old Mar 11, 2008 | 04:52 AM
thook's Avatar
Run a search on pulling codes. It can be done.
Old Mar 11, 2008 | 05:56 AM
js9924's Avatar
depends what year some you can jump the diagnostic port at e1 and te1 then get in the cab and watch the CEL flash (this is obd1 equipped vehicles 2nd gen) count the times it flashes and that is your code. You can search for the codes there are plenty of threads on it. good luck.
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
