i think i toasted my alternator
Old Mar 15, 2008 | 03:57 AM
toy89yota's Avatar
so last night i went through a little bit of mud, not even that bad just enough totry out my tires. well this mornig the battery light and e brake lights stay on when i drove my wife to work. im pretty sure i toasted my alternator any thoughts?
where can i get a high output alternator for her, its a 22re?
Old Mar 15, 2008 | 07:19 AM
INFINITY's Avatar
i would say test it first. might have got some wires wet and shorted out and blew a fuse/VR
Old Mar 15, 2008 | 07:39 AM
881stGenRunner's Avatar
the ebrake light is prolly due to not enough brake fluid in the master cylinder. I would check that first. Also how new is you battery? Check everything first before you just start throwing parts at it.
Old Mar 15, 2008 | 05:06 PM
toy89yota's Avatar
rusty wire haha fixed just some rusty wires
Old Mar 15, 2008 | 05:09 PM
DeathCougar's Avatar
You DO know that when the Alternator and Brake light come on at the same time, there is a charging issue right?
Doesn't always mean alternator, but it means that somewhere in the system there is a problem. If it was the brakes, just the brake light would come on.
Old Mar 16, 2008 | 03:53 AM
toy89yota's Avatar
cool thanks for the info im sure there was a charging issue i had a bad connection at the alternator
Old Mar 17, 2008 | 11:00 PM
notanymore's Avatar
i would take it apart and try and clean it all out first, possibly replace the brushes, its not very hard and they are cheap. this has solved my problems more than once with my alternator.
TheBFA
Feb 15, 2020 06:55 AM
shooter86314
Jan 7, 2016 07:05 AM
Chicken12
Oct 14, 2015 03:54 PM
fountain
Sep 28, 2015 03:04 AM
SCZIG
Sep 20, 2015 09:00 AM
