Temp control stopped working
The switch that controls hot to cold does not switch over to hot air anymore.
It did this once before, and I slammed the switch all the way to the cold side and then back to the hot side and it worked. Now even that does not work. I haven't pulled the dash apart but once when I bought the rig and pulled the double DIN stereo and put my own head unit in. The rear heater still works which makes me think it's not the heater core. Any ideas are much appreciated.
check on the firewall in the engine compartment, the valve assy is located pretty much centered there. check the 'bent' sheet metal clip to make sure it is grabbing the cable, adjust as necessary.
lee
lee
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
icentropy
Jul 11, 2015 07:21 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
