Temp control stopped working
Old Mar 17, 2008 | 11:01 AM
Mattabilly's Avatar
The switch that controls hot to cold does not switch over to hot air anymore.
It did this once before, and I slammed the switch all the way to the cold side and then back to the hot side and it worked. Now even that does not work. I haven't pulled the dash apart but once when I bought the rig and pulled the double DIN stereo and put my own head unit in. The rear heater still works which makes me think it's not the heater core. Any ideas are much appreciated.
Old Mar 17, 2008 | 12:15 PM
leebee's Avatar
check on the firewall in the engine compartment, the valve assy is located pretty much centered there. check the 'bent' sheet metal clip to make sure it is grabbing the cable, adjust as necessary.
lee
Old Mar 17, 2008 | 12:40 PM
Marc's Avatar
The rear heater uses a seperate heater core from the front.
Old Mar 17, 2008 | 02:01 PM
Mattabilly's Avatar
Leebee- Checked your suggestion everything is in order.
Marc- thanks, I just assumed they ran off the same source.
New heater core?
Old Mar 17, 2008 | 04:59 PM
leebee's Avatar
you will more than likely need to replace your switch assy, mine has jammed up on me. not an issue right now as im doing maintenance on it and that switch is on the list!
lee
coryc85
Sep 9, 2015 06:24 AM
icentropy
Jul 11, 2015 07:21 AM
Avenged
Jul 9, 2015 07:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
