coolant temp sensor problems
Old Mar 19, 2008 | 09:06 AM
goodtimeyota90's Avatar
i have a 90 toyota pickup 4x4 that had a cold start problem. i fixed that by changing the coolant temp sensor. it started fine the next cold morning. later that day it stalled, but eventually started back up. now it will just turn over and not start. it used to fire up for about a second but now nothing. i checked the codes and it came up with a 12, which says something about no NE or G signal after cranking, and a code 51 which deals with the switch signal/ neutral start switch (but it turns over??). if anyone has any suggestions let me know please. thanks Tim
Old Mar 19, 2008 | 04:59 PM
TORTIS's Avatar
are you getting gas, and fire? checked your fuses? cold start injector system?
Old Mar 19, 2008 | 05:51 PM
mrnick1979's Avatar
make sure your fuel pump is running while cranking over, check your cor" circuit open relay:
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
bryan34w
Jul 6, 2015 05:53 PM
