22re timing problems....
Old Mar 18, 2008 | 05:05 PM
oilfieldtrash's Avatar
Unhappy 22re timing problems....
Well today i put a new timing set on the 88 toyota i bought. I got it all put back together and now it wont start. i set my timing like 15 times, and still nutttin. it will crank over and act like it wants to start but no go. I pulled a sparkplug and i have spark. Now what?
The truck ran (ty) before i put a new timing set on.
Old Mar 18, 2008 | 05:12 PM
loacyota's Avatar
Why did you pull the spark plug to check spark?
And, if your timing marks are positively on, and it tries to start, your distributor is probably 180 degrees out, everyone does it
Old Mar 18, 2008 | 05:14 PM
rdlsz24's Avatar
You were able to get the timing set to 5 degrees BTDC with the 2 terminals jumped? I finished putting in a new engine on Saturday and couldn't get it to fire at first because the timing was so far off. It would just sputter and backfire.
Rob
Old Mar 18, 2008 | 05:31 PM
i messed with it again tonight....i have tried to start it and then set it back to TDC and tried to start it again...but still no go...am i missing something here?
Old Mar 19, 2008 | 05:02 PM
TORTIS's Avatar
did you get it running? timing could be 180 out, or one tooth off. you getting gas? fuses?
Old Mar 19, 2008 | 05:13 PM
MMA_Alex's Avatar
Rob
how on earth would you do that without the engine running?
you sure you have spark, fuel, compression? crank it over for a little bit, then pull a plug and see if its wet with gas.
100% sure you're got it timed right?
Old Mar 19, 2008 | 06:29 PM
havent had time to mess with it in a couple days,,,its hard with my work schedule...
Old Mar 24, 2008 | 07:03 PM
well i pulled the valve cover and set it at TDC. and messed with the distibuter a lil bit...and bam got it runnin......the only problem is it still dont seem to be running like it should, its fine at high RPM's....but idling its "popping" a lil bit in the motor...what could it be? a bent valve?
Old Mar 24, 2008 | 07:45 PM
fishon1213's Avatar
What do you mean by "popping"? Metallic clatter would be a sticking/bent valve or some valvetrain issue. A "popping" could just be the timing off. Make sure you set the timing correctly by jumping the test connectors in the diagnostic box and listen for the drop in idle.
Old Mar 25, 2008 | 02:29 AM
rdlsz24's Avatar
Is your idle speed at around 750rpm when then engine is warmed up?
Rob
Old Mar 25, 2008 | 05:54 AM
i know that the idle needs adjusted.....if i hold it around 900 rpms, the noise isnt there..........is there a way i can tell if a valve is bent w/o taken the head off??
Old Mar 25, 2008 | 06:11 AM
rdlsz24's Avatar
Yeah you can do a compression test. If you have a bent valve you most likely won't have compression on that cylinder. I doubt it's a bent valve though. How about adjusting them?
Rob
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
Nickdigg
Jul 7, 2015 06:04 AM
bryan34w
Jul 6, 2015 05:53 PM
