'94 22re rough idle?!
Old Mar 10, 2008 | 09:49 PM
mattchstik's Avatar
I have a '94 pickup with 150k miles on a 22re. When I start the truck it seems to run and idle fine. After about a minute or so I notice a miss randomly. No engine codes come on either. I have replaced the plugs, wires, cap & rotor, and checked all the valve clearances, and compression which all seem fine. I was thinking possibly it might be the 02 sensor? Any ideas?
Old Mar 10, 2008 | 09:59 PM
YeloSub7's Avatar
when i read the title i instantly though head gasket, but if compression is fine and you did all that tune up work. o2 sensor sounds like a possibility, but not sure... can't think of anything else
Old Mar 11, 2008 | 10:04 AM
BigBoy60's Avatar
Do you have stock exaust?
Old Mar 11, 2008 | 11:06 AM
rdlsz24's Avatar
Mine does this because I have a shot muffler. I am fixing it soon.
Rob
Old Mar 11, 2008 | 03:49 PM
iamsuperbleeder's Avatar
I see by your avatar you play in the mud a lil bit; suck up any H2O recently? Mine did the same thing after I came half a gallon away from hydro-locking my 22re. Turns out I destroyed my AFM; they don't like water. Simple replace and my problem was solved.
Old Mar 12, 2008 | 09:57 AM
BigBoy60's Avatar
after putting glasspacks on my truck it lowered the back pressure which made my truck idle really low.
Old Mar 12, 2008 | 11:17 AM
Georgiadave's Avatar
Have you cleaned the throttle body? My truck will idle at a low RPM with a dirty throttle body.
Old Apr 3, 2008 | 07:26 PM
mattchstik's Avatar
I do have a crack in my muffler that leaks a bit. Would that cause the miss though? Would installing a k&n air filter cause a miss at all? Is the AFM spoken of above the air flow meter?
Old Apr 3, 2008 | 07:32 PM
DCYota's Avatar
I know you said the light in the dash/engine codes don't come on...but have you checked the diagnostic box jumping the T and E1 ports to see if any codes have been stored previously? Mine was running that way...turned out to be an out of adjustment throttle position sensor, which in turn threw off my timing. After I fixed that and set the timing to factory spec, the misses and sputtering were gone. The code mine brought up was a 41 (TPS), but no check engine light ever came on while driving.
Old Apr 7, 2008 | 09:48 PM
mattchstik's Avatar
I've had this problem for a while and once an oxygen sensor code came up but I found that the wires had melted on the cat and were grounding on the frame and exhaust and haven't had any codes come up since then. None are stored right now.
Old Sep 16, 2008 | 08:33 PM
BAMF_3521's Avatar
Mine is doing pretty much the same as we speak. I was told i need a valve adjustment to fix the compression. Also check your vacuum lines and intake manifold gasket for leaks. Supposeably once i adjust my valve and replace my intake gasket my 22RE will be good. I havent done it yet. I just got it out of the shop after a tune up and it DID help out a bit. but I can still feel the problem. hit me back.
Old Nov 23, 2010 | 10:49 PM
mattchstik's Avatar
Finally fixed my misfire... put some NGK spark plugs in her. Amazing that that's all it took. I've been putting platinum plugs in her for a couple years and that was the whole problem! Runs smooth now...finally.
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
Sep 4, 2015 09:27 AM
v_man
Jul 23, 2015 04:01 PM
